Change date value in BAQ report with code
Thanks Vic but this report has to be by calendar years and not fiscal years
Ephraim
On Mon, Jun 17, 2013 at 4:37 PM, Vic Drecchio
<vic.drecchio@...>wrote:
> Alternatively, consider using InvcHead FiscalYear and Fiscal Period fields
> to accomplish this. I prefer to use FP & FY anyways as sometimes Invoice
> Dates may not be for the correct FY/FP.
> -----Original Message-----
> Of
> Ephraim Feldman
> Sent: Monday, June 17, 2013 4:20 PM
> To: Vantage Yahoo Group
> Subject: Re: [Vantage] Change date value in BAQ report with code
> thanks Ted that gave me some start
> I actually wanted something more complicated I want the user to give a from
> and to date and then the report should print all records from begining of
> the year prior the to date.
> I put 2 date controls not bound to fields that are updating the character01
> and 02 of the reportparam and then update the field3 that actually filters
> the BAQ I hope all this makes sense but it works for me now
> So here is all my code
> Private Sub dteFromDate_Validated(ByVal sender As Object, ByVal args As
> System.EventArgs)
> ' ** Place Event Handling Code Here **
> Dim edvReportParam As EpiDataView =
> CType(oTrans.EpiDataViews("ReportParam"), EpiDataView)
> edvReportParam.Dataview(edvReportParam.Row)("Character01")
> = dteFromDate.Text
> End Sub
> Private Sub dteToDate_Validated(ByVal sender As Object, ByVal args As
> System.EventArgs)
> edvReportParam.Dataview(edvReportParam.Row)("Character02")
> = dteToDate.Text
> Dim dte AS Date = dteToDate.Value.Date
> Dim RptBegin AS Date = DateAdd(DateInterval.Day, -
> DatePart(DateInterval.Day,dte) + 1,DateAdd(DateInterval.Month, -
> DatePart(DateInterval.Month,dte) + 1,DateAdd(DateInterval.Year, -1, dte)))
> edvReportParam.Dataview(edvReportParam.Row)("field3") =
> RptBegin
> End Sub
> Private Sub BAQReportForm_Load(ByVal sender As Object, ByVal args As
> EventArgs)
> ' Add Event Handler Code
> Dim dteFrom As Date = DateAdd(DateInterval.Day, -
> DatePart(DateInterval.Day,today) + 1,DateAdd(DateInterval.Month, -
> DatePart(DateInterval.Month,today) + 1,Today))
> dteFromDate.Value = dteFrom
> dteFromDate.Text = dteFrom.ToString()
> = dteFrom.ToString("MM/dd/yyyy")
> dteToDate.Value = Today()
> dteToDate.Text = Today.ToString()
> = Today.ToString("MM/dd/yyyy")
> DatePart(DateInterval.Month,today) + 1,DateAdd(DateInterval.Year, -1,
> today)))
> RptBegin
> End Sub
> End Class
> On Mon, Jun 17, 2013 at 3:02 PM, Ted Koch <tkoch77@...> wrote:
> > Private Sub dteFrom_ValueChanged(sender As Object, e As
> > System.EventArgs) Handles dteFrom.ValueChanged
> > Dim dteFrom As DateTimePicker = DirectCast(sender, DateTimePicker)
> > Dim dte As Date = dteFrom.Value.Date
> > dteTo.Value = dte.AddMonths(1)
> > End Sub
> > ________________________________
> > From: Ephraim Feldman <effgroups@...>
> > To: Vantage Yahoo Group <vantage@yahoogroups.com>
> > Sent: Monday, June 17, 2013 2:03 PM
> > Subject: [Vantage] Change date value in BAQ report with code
> > Hi All
> > I have a BAQ report with a from date and to date that will filter the
> > Invchead.invoiceDate.
> > I want that when the user changes the "from date" then the "to date"
> > should automatically be set to a month later and then if the user
> > wants he can change it.
> > How can i accomplish that with code?
> > Ephraim
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
Hi All
I want that when the user changes the "from date" then the "to date" should
automatically be set to a month later and then if the user wants he can
change it.
Ephraim
   Private Sub dteFrom_ValueChanged(sender As Object, e As System.EventArgs) Handles dteFrom.ValueChanged
   End Sub
Hi All
change it.
Ephraim
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
I want the user to give a from and to date and then the report should print
all records from begining of the year prior the to date.
the BAQ
System.EventArgs)
= dteFromDate.Text
End Sub
System.EventArgs)
= dteToDate.Text
RptBegin
End Sub
EventArgs)
today)))
RptBegin
End Sub
End Class
> End Sub
> Hi All
> change it.
> Ephraim
Ephraim Feldman
System.EventArgs)
= dteFromDate.Text
End Sub
System.EventArgs)
= dteToDate.Text
RptBegin
End Sub
EventArgs)
today)))
RptBegin
End Sub
End Class
> End Sub
> Hi All
> Ephraim
