Thank you for the response. However, when I tried to implement the code below, I got a lot of errors (some of which were "; expected"). Is the below code in VB? We have our customizations set to be done in C# which may be part of the problem...
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> In 8.03, when I have this problem, I add a button to the form and assign the
> following code to the click event:
>  Dim edvUD105 as EpiDataView = CType(oTrans.EpiDataViews("UD105"), EpiDataView)
> IF edvUD105.HasRow() Then
> Dim chg as Epicor.Mfg.UI.App.ChgLogEntry.ChgLogArgs
> chg.Start(oTrans,"UD105",edvUD105.dataView(edvUD105.Row)("RowIdent").ToString(),true)
> End If
> Substitute the table name of choice (HDcase) for UD105.
> ÂÂ
> From: Adele <arbjorklund@...>
> To: vantage@yahoogroups.com
> Sent: Tue, November 2, 2010 1:20:18 PM
> Subject: [Vantage] Change Log for HDCase Table
> ÂÂ
> Hi,
> We have just gone live with the Case Management portion of Epicor 9.04.506C. We
> realized that we were going to need a change log for Cases as there are quite a
> few fields that multiple people can touch and it is important that we don't lose
> information.
> Using a BAM, I was able to create an event on the HDCase table and then I select
> Create Log as the Action. However, I don't see where I can access this log. When
> I look on the toolbar and in the Actions menu in Case Entry, I don't see an
> option for Change Log.
> Does anyone know if this is something that can be added or if there is another
> way of accessing the log?
> Thanks,
> Adele
> ÂÂ
