Change Part Class on PO Entry
Rob,
I've had a go and it looks like it works for what we need
Thanks for your help
Mark Taylor
Senior Document Controller
Of robertb_versa@...
Sent: 28 July 2010 11:38
Subject: Re: [Vantage] Change Part Class on PO Entry
That's native behavior. If you unapprove (which must be done to do ANY
editing - including closing the line short & entering a new one), you
can over-ride inspection req'd..
You shouldn't lose any re traceability as the initial receipt records
(pack list detail, parttran records) will show inspection req'd &
processed.
...Just a thought. (We do this.)
Rob
--- Original Message ---
<mailto:mark.taylor%40hansatechems.com> >
Sent:Wed 7/28/10 3:27 am
To:<vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Subj:Re: [Vantage] Change Part Class on PO Entry
Unfortunately the Inspection required Box is greyed out, so we can't.
This is for approved PO lines
To be honest the only option I can see at the moment would be to close
the line and re-enter it.
Mark Taylor
Hansatech EMS provides value manufacturing through engineering and
quality
Hansatech EMS Limited
Benson Road
Nuffield Industrial Estate
Poole
Dorset BH17 0RY
United Kingdom
Tel:
Fax:
DDI:
+44 (0)1202 338200
+44 (0)1202 338202
+44 (0)1202 338228
Mark.Taylor@... <mailto:Mark.Taylor%40HansatechEMS.com>
www.HansatechEMS.com
______________________________________________________________________
This email has been scanned by the MessageLabs Email
Hi All,
Does anyone know of a way to change the part class on the PO Entry screen?
Basically we have some parts that are set to go straight to inspection, and so they have a specific part class. After a while or as instructed by our customer these parts no longer need to go through to inspection. So I change the Part class on Part Entry, but the PO line still shows the part as Inspection Required. We know this is because the PO takes a snapshot of the part at the time it was raised.
Is there a way to update the part information on the PO?
Regards
Mark
Why not just over-ride it and uncheck inspection req'd (within the PO) when you reach that level of confidence?
Rob
Sent:Tue 7/27/10 10:58 am
To:vantage@yahoogroups.com
Subj:[Vantage] Change Part Class on PO Entry
Hi All,
Regards
Mark
Mark Taylor
quality
Benson Road
Poole
Dorset BH17 0RY
United Kingdom
Tel:
Fax:
DDI:
+44 (0)1202 338200
+44 (0)1202 338202
+44 (0)1202 338228
Mark.Taylor@...
That's native behavior. If you unapprove (which must be done to do ANY editing - including closing the line short & entering a new one), you can over-ride inspection req'd..
You shouldn't lose any re traceability as the initial receipt records (pack list detail, parttran records) will show inspection req'd & processed.
Rob
To:<vantage@yahoogroups.com>
Mark Taylor
quality
Benson Road
Poole
Dorset BH17 0RY
United Kingdom
Tel:
Fax:
DDI:
+44 (0)1202 338200
+44 (0)1202 338202
+44 (0)1202 338228
Mark.Taylor@...
