Change sequence numbers in Financial Report Designer
Is it possible to change the sequence numbers in Financial Report Designer? I found out (the hard way) that you can only have a 4-digit sequence number. I am new to Vantage, but other systems I have worked on had a utility that would renumber the rows automatically by defining the start number and then an incremental number.
Since the sequence number is now grayed out, I can't change it manually. Has anyone run in to this problem? If so, how did you resolve it?
