I’m using BOs in a BPM and need to change a value in a Dataset between objects. I’m assuming I can do this with C# code, but not sure of the syntax.
My dataset variable name is RMADispDataSet and I need to access the RMADisp.ReasonCode field.
Something like this?
using(var UD05Svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.UD05SvcContract>())
//get new row
var ds = new Ice.Tablesets.UD05Tableset();
UD05Svc.GetaNewUD05(ref ds);
//modify ds
var newUD05Row = ds.UD05.FirstOrDefault();
newUD05Row.Company = "JRF";
newUD05Row.Key1 = DateTime.Now.ToString();
newUD05Row.Key2 = "update_status";
newUD05Row.Key3 = "";
newUD05Row.Key4 = "";
newUD05Row.Key5 = "";
newUD05Row.Date01 = DateTime.Now;
newUD05Row.Character01 = json;
//update
UD05Svc.Update(ref ds);
Or if returning a dataset, access the table:
var svc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.QuoteSvcContract>();
var ds = svc.GetByID(QuoteNum);
//ChangePartNum
ds.QuoteDtl[0].PartNum = PartNum;
svc.ChangePartNum(ref ds, false, "");
That got me on the right path. Since the dataset was already created as global BPM variable, all I needed to do was create one line.
RMADispDataSet.RMADisp[0].ReasonCode = “MYREASON”;
