Changing a Primary Bin Location with a handheld
So, I have tried many ways to do this but still getting error messages. I don't know this language at all and this is my first BPM. I have added a check box and Epibinded it to CallContextBPMData.Checkbox01 to my "Move Inventory" Hand Held Screen to start the action. Anyone able to help me fix the code so I can get this running for me?
The errors I am getting are as follows;
Cannot Find NEXT LEAVE RETRY or UNDO label appropriate block. (209)
Could not understand Line 1. (196)
Unknown Field or Variable name - exceptionOccured__. (201)
Could not understand line 1 (196)
and the code is as follows;
/*Add source code that should be executed before the designed actions here*/
for each ttInvTrans where ttInvTrans.RowMod = 'U' or ttinvtrans.RowMod = 'A'.
find PlantWhse where PlantWhse.Company = CUR-COMP and PlantWhse.PartNum =
ttinvtrans.PartNum and PlantWhse.WarehouseCode = "RACOMAIN" and
ttinvtrans.ToWarehouseCode = "RACOMAIN" NO-ERROR.
IF AVAILABLE PlantWhse THEN DO:
FOR EACH ttCallContextBPMData WHERE ttCallContextBPMData.checkbox01 = True:
Run lib\UpdateTableBuffer.p(input BUFFER PlantWhse:HANDLE, 'PrimBin',
ttinvtrans.ToBinNum).
end.
end.
{&CALL_DESIGNED_ACTIONS}
end.
end.
/*Add source code that should be executed after the designed actions here*/
--- In vantage@yahoogroups.com, "Drew" <ahsalloum@...> wrote:
> Ok, let me try that. I just sent you an email. Just disregard the email.
> --- In vantage@yahoogroups.com, "Gerry Loranger" <gloranger@> wrote:
> > Try adding a checkbox on the screen and bind it to
> > CallContextBpmData.Checkbox01. Then add "CallContextBpmData.Checkbox01 =
> > True" to the criteria below .
> > > 'A'.
> > > ttinvtrans.PartNum and PlantWhse.WarehouseCode = "MAIN" and
> > > ttinvtrans.ToWarehouseCode = "MAIN".
> > > if avail PlantWhse then do:
> > > end.
> > > end.
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > Drew
> > Sent: August-09-12 1:58 PM
> > Subject: [Vantage] Re: Changing a Primary Bin Location with a handheld
> > Rick, I actually had the exact idea. How easy would it be to just have the
> > WH worker hit a check box to make it the primary. I just wish I knew how to
> > do it. I will let you know if I ever figure it out.
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > "that_guyy" <rbird@> wrote:
> > > Drew,
> > > About a year ago I wanted to do the same thing from the handheld when the
> > user is using the Move Inventory HH program.
> > > The scenario was, whenever the user/mtl handler was moving inventory
> > around (often times for whs reorganization, etc) we wanted the ability for
> > the user to indicate that the TO WHS & the TO BIN would be the new Primary
> > WHS & Primary BIN in that whs.
> > > My idea (never implemented) was to add a checkbox to the form labeled
> > 'Make Primary' between the WHS/Bin and Lot fields.
> > > Then have a BPM on the... whatever Method Directive... to check and see if
> > the checkbox was checked, if it was then to run some ABL code that would
> > grab the To whs & To Bin and update that part's primary whs and, it's
> > primary bin for the CURRENT Plant to those values.
> > > Everyone liked the idea and thought it would be easy enough to use, but I
> > never got to that project before I moved on to another employer.
> > > Perhaps this helps? I can help more if you need... or I would think others
> > in the group would have experience with BPM's & ABL in BPM's if you need.
> > > -Rick Bird
> > > IT Software Administrator
> > > Rowmark, LLC.
> > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Drew"
> > <ahsalloum@> wrote:
> > > > Thanks guys for all the suggestions.
> > > > I knew it was in PlantWhse, but how do I get that on the hand held
> > screen? When I add a EpiTextBox, can I assign that box as the primebin under
> > planwhse. That is my confusion. I guess I don't know how to add a field on
> > the screen and assign it to be any field/table, unless it is already listed
> > in EpiBinding drop down list.
> > > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Mark
> > Wonsil <mark_wonsil@> wrote:
> > > > > Hi Drew,
> > > > > > Jose, I have also customized a lot of my hand held screens, but
> > can't find the field for the primary.
> > > > > It's in PlantWhse.
> > > > > Mark W.
From my experience, there is no way to update the primary to a new bin with the handheld guns. I don't know if I am unique with updating primary locations often, but I wanted to reach out to you guys and see if there is anyone out there with my same issue.
Has anyone customized a way to do that?
If so, what did you do?
If not, how do you handle that process on daily basis?
If you figure it out let me know. sounds pretty cool.
Josh Serwe
Manager of Warehouse & Logistics
920.437.6400 Ext. 330
Safety
Professionalism
Effectiveness
Easy
Demand Results
<http://www.wisconsinconverting.com>
FYI, I am on 9.05.607
I will Josh.
> Josh Serwe
> Safety
> Professionalism
> Effectiveness
> Easy
> Demand Results
The hand held screens are customizable just like any other screen in the
system, it wouldn't be hard to accomplish this, bring in the required
feilds, and the adapters.
I haven't done this particular one, but Iv'e customized several hand held
menus.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
Jose, I have also customized a lot of my hand held screens, but can't find the field for the primary. There are fields for bins, but as you know those are not the same thing. I know you said you have not tried it, but if you think you know maybe we can discuss this further if you have some time.
> menus.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
I believe you use just set the primary flag on the appropriate PartBin
record. I don't think 'Primary Bin' is a separate field.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> > menus.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> primary
> there is
John, Can you please elaborate further. I am fairly new to customization and don't completely understand what you are referring to.
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > > menus.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > primary
> > there is
Primary bin is held in PlantWhse.PrimBinNum
They couldn't hide it any better if they tried
> > menus.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
Hi Drew,
It's in PlantWhse.
Mark W.
I knew it was in PlantWhse, but how do I get that on the hand held screen? When I add a EpiTextBox, can I assign that box as the primebin under planwhse. That is my confusion. I guess I don't know how to add a field on the screen and assign it to be any field/table, unless it is already listed in EpiBinding drop down list.
--- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@...> wrote:
> Hi Drew,
> It's in PlantWhse.
> Mark W.
Can one of the guys that responded please elaborate how to add a primary flag on one of the hand held processes? For example, on the "Move Inventory" screen, can a check box or extra field be added to update the primary location?
> --- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@> wrote:
> > Hi Drew,
> > It's in PlantWhse.
> > Mark W.
I am trying to update the primary bin from the hand held. Does anyone do that from the hand held. If so, can you help?
> > Hi Drew,
> > It's in PlantWhse.
> > Mark W.
Drew,
About a year ago I wanted to do the same thing from the handheld when the user is using the Move Inventory HH program.
The scenario was, whenever the user/mtl handler was moving inventory around (often times for whs reorganization, etc) we wanted the ability for the user to indicate that the TO WHS & the TO BIN would be the new Primary WHS & Primary BIN in that whs.
My idea (never implemented) was to add a checkbox to the form labeled 'Make Primary' between the WHS/Bin and Lot fields.
Then have a BPM on the... whatever Method Directive... to check and see if the checkbox was checked, if it was then to run some ABL code that would grab the To whs & To Bin and update that part's primary whs and, it's primary bin for the CURRENT Plant to those values.
Everyone liked the idea and thought it would be easy enough to use, but I never got to that project before I moved on to another employer.
Perhaps this helps? I can help more if you need... or I would think others in the group would have experience with BPM's & ABL in BPM's if you need.
-Rick Bird
Rowmark, LLC.
> > Hi Drew,
> > It's in PlantWhse.
> > Mark W.
I implemented this method a couple years ago. Works great. Create a new BPM
in InvTransfer.CommitTransfer. No condition is required, simply add the
following ABL code in the actions:
'A'.
end.
end.
that_guyy
Sent: August-08-12 8:56 AM
Drew,
-Rick Bird
Rowmark, LLC.
> > Hi Drew,
> > It's in PlantWhse.
> > Mark W.
Thanks Gerry. I will try it, but wanted to confirm first. Does this BPM make the "To" location the Primary bin everytime? The reason I ask is because I don't want to make the "To" location the primary on every transfer.
> 'A'.
> end.
> end.
> that_guyy
> Drew,
> -Rick Bird
> Rowmark, LLC.
> > > Hi Drew,
> > > It's in PlantWhse.
> > > Mark W.
Rick, I actually had the exact idea. How easy would it be to just have the WH worker hit a check box to make it the primary. I just wish I knew how to do it. I will let you know if I ever figure it out.
--- In vantage@yahoogroups.com, "that_guyy" <rbird@...> wrote:
> Drew,
> -Rick Bird
> Rowmark, LLC.
> > > Hi Drew,
> > > It's in PlantWhse.
> > > Mark W.
> 'A'.
> end.
> end.
Drew
> Drew,
> -Rick Bird
> Rowmark, LLC.
> > > Hi Drew,
> > > It's in PlantWhse.
> > > Mark W.
> > 'A'.
> > end.
> > end.
> Drew
> > Drew,
> > -Rick Bird
> > Rowmark, LLC.
> > > > Hi Drew,
> > > > It's in PlantWhse.
> > > > Mark W.
