Changing Case on Chart of Accounts Descriptions
Hi Todd,
> From your suggestion though....
> Ctrl-C in Vantage
> Ctrl-V in a cell in Excel
> Adjacent cell refers to paste cell with Proper() function
> Copy the value in function cell (or have a thrid cell refer to the value
> only of the function cell)
> Ctrl-V in Vantage
> Significantly fewer steps and no single letter selection mouse action.
That would change it in Vantage. I was thinking of just running the =proper()
in your FRx Excel sheets. Just a thought...
Mark W.
I have been asked to see if there might be a fairly painless way to change our currently all CAPS descriptions on the Chart of Account to be normal form (first letter Caps, rest lower case). Apparently our CFO is finding all caps makes FRx reports hard to read and would rather change the chart of accounts than play with it in FRx (if FRx can even do that).
So a couple questions:
1. Any known impact from using a program to cosmetically change a field's value? Especially a description field that is part of an index? Does case matter in an index?
2. Assuming someone had the type of Progress tool required to write to the DB does said tool have a "Caps" or "LC" type function as well as a "Substring" type function? Or, with ODBC set to write could I use an Access query? Of course I would test this on a test database.
Worst case....a half dozen of us split up the chart and start re-typing but we were looking for something faster/easier.
Todd Caughey
Harvey Vogel Mfg. Co.
If you don't mind just changing until it hits Excel, you can use the =proper()
function to capitalize the first character of each word in a cell.
Mark W.
Good idea. I was playing around with Word and Shift-F3 as in:
Ctrl-C in Vantage
Ctrl-V in Word
Ctrl-A to select all
Shift-F3 (change case to all lower)
Select first letter and Shift-F3 to capitalize first letter (multiple Shift-F3 won't caps only first word)
Ctrl-A
Ctrl-X (cut)
In Vantage Ctrl-V
All this does is save typing and assure no typos worse than present but this sure is tedious still. I can type faster than I can do the above if the description is small.
Ctrl-C in Vantage
Copy the value in function cell (or have a thrid cell refer to the value only of the function cell)
Ctrl-V in Vantage
Significantly fewer steps and no single letter selection mouse action. Thanks,
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Mark Wonsil
Sent: Wednesday, April 12, 2006 7:43 PM
Subject: RE: [Vantage] Changing Case on Chart of Accounts Descriptions
Mark W.
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
