There are still a few reports in 8.03 that don't use Crystal and the Variance Report is one of them.
Sent: Friday, September 20, 2013 10:46 AM
Subject: RE: Re: [Vantage] Changing or replacing "Plain Text" reports (Ver 8.03)
<div id="ygrps-yiv-944386650yiv1610806088ygrp-text">
<div>I'm on 905 so I cant really speak to how its done on 803, but aren't reports run from crystal? </div> <div class="ygrps-yiv-944386650yiv1610806088ygroups-quoted"><br><br><blockquote><span title="qreply"> --- In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:<br><br><div id="ygrps-yiv-944386650yiv1610806088ygrps-yiv-804121161"><div style="color:rgb(0, 0, 0);background-color:rgb(255, 255, 255);font-family:'times new roman', 'new york', times, serif;font-size:12pt;"><div><span>As far as I know you can't change them unless you have the SDK.</span></div><div><br></div> <div style="font-family:'times new roman', 'new york', times, serif;font-size:12pt;"> <div style="font-family:'times new roman', 'new york', times, serif;font-size:12pt;"> <div dir="ltr"> <hr size="1"> <font size="2" face="Arial"> <b><span style="font-weight:bold;">From:</span></b> "ckrusen1@..." <ckrusen1@...><br> <b><span style="font-weight:bold;">To:</span></b> vantage@yahoogroups.com <br> <b><span
style=“font-weight:bold;”>Sent: Friday, September 20, 2013 8:17 AM
Subject: [Vantage] Changing or replacing “Plain Text” reports (Ver 8.03)
<div id="ygrps-yiv-944386650yiv1610806088ygrps-yiv-804121161yiv9093334478ygrp-text">
<div>Is there a way to change or replace the system reports - the ones that only have a report style of "Plain Text"? </div><div><br></div><div>For example, when you select "Print Variance Report" when in the Count Group Entry screen, the only Style choice available is "Plain Text".</div><div><br></div><div>If the report can't be modified or replaced, is there at least a way to have it render and print in landscape instead of portrait?</div><div><br></div><div>Version 8.03.409c</div><div><br></div><div>Thanks in advance, Calvin</div>
</div>
</div>
