Changing Sub Components in Finished Stock(v6.1)
Thanks that works great
--- In vantage@yahoogroups.com, "ami_miker" <mrandolph@...> wrote:
> The easiest way to fix this is to create a new job for Part 1000,
> but don't use the standard BOM for the part. Add an operation for
> the repair activities, and issue Part 1000 and Part B to the job.
> If Part A is reusable, you can salvage part A and put it back in
> stock.
> Now, be aware of your costing method when you do this. Standard
> costing will create a variance (not a bad thing). Average costing
> will increase a little because the reworked Part 1000 is more
> expensive due to the substitution of Part B (not a problem if you
> don't keep inventory). Last costing will be more troublesome.
> I hope this helps.
> Michael Randolph
> Infinity Business Consulting
> mrandolph@...
> Office: 865-329-3000
> --- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@>
> wrote:
> > Hi,
> > We have a situation where we have manufactured an assembly which
> has
> > been received into finished stock. We now need to replace a
> > component in the assembly with another part which as a greater
> cost.
> > I am not sure how to do this. If with issue the stock item back
to
> > the job then this brings the whole assembly rather than the
> > individual components or BOM.
> > We don't the advance materials module.
> > Affectively, this what we have.
> > IN finished Stock , PART 1000, which is the assembly which
> contains
> > PART A.
> > We need to replace PART A with PART B.
> > I would like to see the transactions of the replacement in
vantage
> > so we can track and the stock is correct. If this not possible ,
I
> > think I would need to use some sort adjustment to show the
> financial
> > impact.
> > If anybody could help me out that would be fantastic.
> > Many thanks
Hi,
We have a situation where we have manufactured an assembly which has
component in the assembly with another part which as a greater cost.
I am not sure how to do this. If with issue the stock item back to
IN finished Stock , PART 1000, which is the assembly which contains
PART A.
I would like to see the transactions of the replacement in vantage
so we can track and the stock is correct. If this not possible , I
think I would need to use some sort adjustment to show the financial
impact.
Many thanks
stock.
I hope this helps.
Michael Randolph
mrandolph@...
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@...>
wrote:
> Hi,
has
cost.
contains
> PART A.
financial
> impact.
> Many thanks
