Character field grouping 6.1
Hi Bruce
It's because it is a memo field and crystal doesn't like memo fields.
You will find you cannot create formula with them either. In Vantage
8.00 Epicor have got around by introducing shortcharXX as well.
The way you would work around this, is by using an SQL expression (in
crystal) which would convert the data to a string (maybe truncate it),
so the field can be used
Hope it helps
Gary Parfrey
Of Bruce Butler
Sent: 26 July 2006 18:46
Subject: [Vantage] Character field grouping 6.1
Is there any reason I am missing where I cannot group within Crystal 8.5
on characterX fields (VB FORMS)? There is no error message. It
simply does not show as a field I can group on. It does show as a field
I can include within the details of the report.
Bruce Butler, IT Manager
bbutler@... <mailto:bbutler%40knappe-koester.com>
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
bbutler@...
