Is there any way to increase a character limit for a field on a form?
The character limit for the description for Packaging Classification is only 40, and I was wondering if there is a way I can increase that?
No, you can put a call in with Epicor and suggest an Enhancement. Only way is to make your own field and replace that one with your own (the most safest way).
I’ve got a similar situation.
Any change 10.2.700 has a new ability to increase the number of characters in the UDCodes.CodeID? Or that suffers the same limitation? I guess an alternative would be to recreate it all in UD Tables. Or just join on the UDCodes.CodeDesc field instead…
