Hello Group,
I have a question regarding the Chart Tracker (Financial Management > General Ledger > General Operations > Chart Tracker)
In this screen there is a tab I want to add some columns to. I want to add PO Num and Part Num to the grid located on Transaction Detail > Specific > Detail tab. This grid shows Journal Entry Detail information. If you highlight a rows there then click on the Transaction Detail > Specific > Cost Transaction tab and click retrieve it grabs information for that journal entry. I want to add the PO Num and Part Num field from this grid to the first grid from the Detail Tab.
However I'm unable to find the way the Cost Transaction tab is getting the information. When I trace what happens when the retrieve button is clicked it shows the gird is using BO GLCostTrans and Method GetRowsCustom. The only parameter that is being entered is the glJrnDtlRowid.
I've used the BO reader and dynamic queries to add columns to grids however I'm not sure on how to apply the glJrnDtlRowid to achieve the goal of adding the column's values. Any insight into this would appreciated.
Have you tried the personalization to add these columns?
All grid views have certain fields that are “hiddenâ€. Once you know what fields are there, you can unhide them.
All you do is right-click on a grid view and click on personalization (or click on Tools – personalization – then click on the grid view). Click on the actual grid….you should see the Columns row (with Collection). Click on collection so that the drop down arrow comes up and see if those fields are there. You can sort the field name column to find the fields easier.
I did not check on the grid view you mentioned to see if those fields are available. Just throwing that out there.
M. Manasa Reddy
manasa.reddy@...
281-994-3483 [d] | 773-401-4126 [m]
Sent: Monday, June 30, 2014 1:37 PM
Subject: [Vantage] Chart Tracker Add Column
Hello Group,
<div id="ygrps-yiv-951168233yiv5729120459ygrp-text">
<div>Thanks for the response,</div><div><br clear="none"></div><div>yes, these columns are not available in the grid currently. I will need to add them via the BO Reader or Dynamic Query. However I'm not sure how the second grid is using the information in first grid to retrieve the PO and Part Number. It looks like it is using the glJrnDtlRowID, but i'm not sure how that is being used.</div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mkp #ygrps-yiv-951168233yiv5729120459hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mkp #ygrps-yiv-951168233yiv5729120459ads {
margin-bottom:10px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mkp .ygrps-yiv-951168233yiv5729120459ad {
padding:0 0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mkp .ygrps-yiv-951168233yiv5729120459ad p {
margin:0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mkp .ygrps-yiv-951168233yiv5729120459ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-sponsor #ygrps-yiv-951168233yiv5729120459ygrp-lc {
font-family:Arial;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-sponsor #ygrps-yiv-951168233yiv5729120459ygrp-lc #ygrps-yiv-951168233yiv5729120459hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-sponsor #ygrps-yiv-951168233yiv5729120459ygrp-lc .ygrps-yiv-951168233yiv5729120459ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459activity span {
font-weight:700;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459activity span span {
color:#ff7900;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459activity span .ygrps-yiv-951168233yiv5729120459underline {
text-decoration:underline;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459attach div a {
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459attach img {
border:none;padding-right:5px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459attach label a {
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459bold a {
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 dd.ygrps-yiv-951168233yiv5729120459last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 dd.ygrps-yiv-951168233yiv5729120459last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 dd.ygrps-yiv-951168233yiv5729120459last p span.ygrps-yiv-951168233yiv5729120459yshortcuts {
margin-right:0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459attach-table div div a {
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459attach-table {
width:400px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459file-title a, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459file-title a:active, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459file-title a:hover, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459file-title a:visited {
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459photo-title a, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459photo-title a:active, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459photo-title a:hover, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div.ygrps-yiv-951168233yiv5729120459photo-title a:visited {
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 div#ygrps-yiv-951168233yiv5729120459ygrp-mlmsg #ygrps-yiv-951168233yiv5729120459ygrp-msg p a span.ygrps-yiv-951168233yiv5729120459yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459green {
color:#628c2a;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 o {
font-size:0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459photos div {
float:left;width:72px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459reco-category {
font-size:77%;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459reco-desc {
font-size:77%;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 .ygrps-yiv-951168233yiv5729120459replbq {
margin:4px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mlmsg select, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 input, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mlmsg pre, #ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 code {
font:115% monospace;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-mlmsg #ygrps-yiv-951168233yiv5729120459logo {
padding-bottom:10px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-msg p#ygrps-yiv-951168233yiv5729120459attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-reco #ygrps-yiv-951168233yiv5729120459reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-sponsor #ygrps-yiv-951168233yiv5729120459ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-sponsor #ygrps-yiv-951168233yiv5729120459ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-sponsor #ygrps-yiv-951168233yiv5729120459ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-text {
font-family:Georgia;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-text tt {
font-size:120%;}
#ygrps-yiv-951168233 #ygrps-yiv-951168233yiv5729120459 #ygrps-yiv-951168233yiv5729120459ygrp-vital ul li:last-child {
border-right:none !important;}
You can also add them with a BPM using the User define fields.
Sent: Monday, June 30, 2014 1:20 PM
Subject: RE: [Vantage] Chart Tracker Add Column
