Check in part, meaningful Description Of Change
From the engineering Workbench, you can check in and approve methods, by default the description of the change is entered. (as seen in the screenshot), is there any way to clear this sreen (make it blank). and require someone to fill in something meaningfull?
regards,
I’m guessing you can customize that popup and clear the textbox on load. Then when the form is closing check that there is text in the textbox.
