My AR Form SSRS report will occasionally error because
… The Hidden expression for the tablix ‘Table1’ contains an error. The expression references the field ‘CHISRCodeLine’, which does not exist in the fields collection. Expressions can only refer to fields within the current dataset scope…
So here is where I am stumped. I’ve recently made a change to this SSRS report completely un-related to the CHISRCodeLine. The CHISRCodeLine is in the original SSRS Report and I didn’t change the report data definition at all. This error only seems to happen on the changed report not the old one. I verified that CHISRCodeLine field is in the old report.
The error suggests the field is missing in the dataset which to me says the report data definition but I didn’t make a change to the RDD. I also have no idea what CHISRCodeLine is/means/is used for. Unfortunately Field security maintenance is not exceptionally helpful in this either where the description is ‘CHISRCodeLine’.
Any suggestions or leads others would suggest I look into?
Max
