We did the same thing as Tom did with our Vntgwork folder, with
the only difference is that we did use the users Homedrive on the
Citrix/Terminal Server. As far as the published application goes,
I made a copy of our vantage.vtg file, and changed the vntgwork
folder in there, and then on the command line for the application
we have "R:\vantage\vantage.exe R:\vantage\termsrv.vtg", where the
R drive is mapped to our Vantage server. We haven't had many
problems at all running as a published application this way.
For the connection errors, there are two different places that the IP
address of the citrix server can be entered. One is for making the
connection to the desktop, the other affects published applications.
To set the one for Published apps, when the Program neighborhood
first starts, click in the middle of the screen, so that nothing is
highlighted,
the click on Properties from the file menu. I usually choose to always
use TCP/IP, and then put in the address of the server. Then you
should be able to connect to the published applications that you have
setup.
If you have any questions, let me know. Good luck!!
Tim Care
Electro Chemical Finishing
highlighted,
setup.
Tim Care
----- Original Message -----
To: <vantage@egroups.com>
Sent: Thursday, January 25, 2001 4:06 PM
Subject: RE: [Vantage] Citrix Nightmare!
> I received a couple requests for our work arounds, so here goes. We
upgraded
> to v4 and Windows 2000 Citrix server on Thanksgiving weekend, and Monday
> everything fell apart. (Christmas day was the only day off I had during
> December.)
> For the 'Control Frame' errors:
> As best I could tell from many conversations with Epicor Tech Support,
these
> errors are due to file sharing violations in the "vntgwork" directory. Our
> solution was to provide a network share that contains a seperate folder
for
> each user. Each user folder contains the Vantage working directory. We
then
> map their J: drive to this folder. So, when logged onto the Citrix server,
> every J:\ drive is actually \\USA\Users\%username%. Windows Explorer shows
> J:\vntgwork as a valid path. This is the Vantage work folder I used when
> installing Vantage on the Citrix server.
> (NOTE: I didn't use the users Home directory because I wanted easy access
to
> these folders to delete Vantage working files if necessary. This is
> sometimes necessary when a Citrix connection is dropped or disconnected or
> whatever happens to them.)
> For the "PROMSGS" errors:
> I never could get a good reason why this happens on Windows 2000. But our
> work-around is about 95%. I created a PROMSGS folder under every users
> J:\vntgwork folder and copied the X:\Progress\PROMSGS file to this new
> folder. I then added a line to the vantage.ini file on the Citrix server.
> Right after the PROPATH statement. I added
> PROMSGS=J:\vntgwork\promsgs\promsgs. (On a new line, of course.) I also
> received the suggestion to move the promsgs.dll & catagory.dll files to
the
> system32 folder on my server. This didn't seem to make any difference.
> These steps seemed to solve most errors. My Vantage.lg file still fills up
> with the promsgs error sometimes, but users don't see it. I'm still
working
> on why.
> For all of the following erors:
> >Error in connection.
> >The Citrix Server is not available, please try again later.
> >Cannot connect to the Citrix server:
> >Transport Driver error
> >Unable to contact the Citrix Server Browser.
> >Security Control information is Missing (sec419)
> >The entered credential information is incorrect.
> >There are no applications available for the supplied credentials in the
> current Application Set.
> These all seem to be related to Published Apps. The only work around we've
> found is to have users connect to the Citrix server desktop. We created
> shortcuts for various apps under each profile and that's how we're running
> now. This is actually my third week of relative peace and quite. If I ever
> figure out how to get the published apps running I'll have to re-train all
> my users.
> I hope this helps somebody.
> Tom Taylor
> I.S. Administrator
> Teklution, LLC
> www.teklution.com
