We were struggling with identifying all screen changes that were done in classic when we are trying to re-create / convert to Kinetic.
The below function can be added at the End of any classic customization and invoked in InitializeCustom code it will run through all the custom or moved / changed controls and visually highlight them for you to make the changes easier to spot.
Simply add this at the bottom of your classic customization
private void ColorChange()
foreach(System.Collections.DictionaryEntry controls in csm.PersonalizeCustomizeManager.ControlsHT)
if(csm.CustomCodeAll.Contains(controls.Key as String) && (controls.Value as IInfragisticsAppearance!=null))
// Color and Style Hidden Controls
if(!((Control)controls.Value).Visible)
((Control)controls.Value).Visible = true;
((IInfragisticsAppearance)controls.Value).Appearance.BorderColor=System.Drawing.Color.SpringGreen;
((IInfragisticsAppearance)controls.Value).Appearance.BackColorDisabled = System.Drawing.Color.SpringGreen;
((IInfragisticsAppearance)controls.Value).Appearance.BackColorDisabled2 = System.Drawing.Color.SpringGreen;
((IInfragisticsAppearance)controls.Value).Appearance.ForeColor = System.Drawing.Color.Black;
((IInfragisticsAppearance)controls.Value).Appearance.ForeColorDisabled = System.Drawing.Color.Black;
((IInfragisticsAppearance)controls.Value).Appearance.BackColor = System.Drawing.Color.SpringGreen;
((IInfragisticsAppearance)controls.Value).Appearance.BackColor2 = System.Drawing.Color.SpringGreen;
if(controls.Value as Infragistics.Win.UltraControlBase!=null)
((Infragistics.Win.UltraControlBase)controls.Value).UseOsThemes=Infragistics.Win.DefaultableBoolean.False;
((Infragistics.Win.UltraControlBase)controls.Value).UseAppStyling=false;
EpiTextBox txtNew = new EpiTextBox();
txtNew.Appearance.BorderColor=System.Drawing.Color.SpringGreen;
txtNew.Appearance.BackColor = System.Drawing.Color.SpringGreen;
txtNew.Appearance.BackColor2 = System.Drawing.Color.SpringGreen;
txtNew.UseAppStyling=false;
txtNew.UseOsThemes=Infragistics.Win.DefaultableBoolean.False;;
txtNew.Text="<-- Hidden";
Control parent = ((Control)controls.Value).Parent;
txtNew.Location= ((Control)controls.Value).Location;
txtNew.Left=txtNew.Left+((Control)controls.Value).Width;
txtNew.Width = 65;
parent.Controls.Add(txtNew);
txtNew.BringToFront();
// Color and style native controls that have been moved/modified/changed
else{
((IInfragisticsAppearance)controls.Value).Appearance.BorderColor=System.Drawing.Color.Bisque;
((IInfragisticsAppearance)controls.Value).Appearance.BackColorDisabled = System.Drawing.Color.Bisque;
((IInfragisticsAppearance)controls.Value).Appearance.BackColorDisabled2 = System.Drawing.Color.Bisque;
((IInfragisticsAppearance)controls.Value).Appearance.ForeColor = System.Drawing.Color.DodgerBlue;
((IInfragisticsAppearance)controls.Value).Appearance.ForeColorDisabled = System.Drawing.Color.DodgerBlue;
((IInfragisticsAppearance)controls.Value).Appearance.BackColor = System.Drawing.Color.Bisque;
((IInfragisticsAppearance)controls.Value).Appearance.BackColor2 = System.Drawing.Color.Bisque;
foreach(System.Collections.DictionaryEntry control in csm.CustomControlDictionary)
// Color and style custom controls
if(control.Value as IInfragisticsAppearance!=null)
((IInfragisticsAppearance)((System.Collections.DictionaryEntry)control).Value).Appearance.BorderColor=System.Drawing.Color.LemonChiffon;
((IInfragisticsAppearance)control.Value).Appearance.BorderColor=System.Drawing.Color.LemonChiffon;
((IInfragisticsAppearance)control.Value).Appearance.BackColorDisabled = System.Drawing.Color.LemonChiffon;
((IInfragisticsAppearance)control.Value).Appearance.BackColorDisabled2 = System.Drawing.Color.LemonChiffon;
((IInfragisticsAppearance)control.Value).Appearance.ForeColor = System.Drawing.Color.Coral;
((IInfragisticsAppearance)control.Value).Appearance.ForeColorDisabled = System.Drawing.Color.Coral;
((IInfragisticsAppearance)control.Value).Appearance.BackColor = System.Drawing.Color.LemonChiffon;
((IInfragisticsAppearance)control.Value).Appearance.BackColor2 = System.Drawing.Color.LemonChiffon;
if(control.Value as Infragistics.Win.UltraControlBase!=null)
((Infragistics.Win.UltraControlBase)control.Value).UseOsThemes=Infragistics.Win.DefaultableBoolean.False;
((Infragistics.Win.UltraControlBase)control.Value).UseAppStyling=false;
Then at the end of InitializeCustomCode invoke the fuction
ColorChange();
The resulting screen will look like this
Orange/Blue Text = Native controls that have been moved/modified/changed
Yellow/Coral Text = Custom Controls
Green = A hidden control these controls also get a special â arrow pointing to them cause they are ânewâ and may be missed. We turned them from âhiddenâ to âvisibleâ and higlight them in green.
Hope this helps
