Hey there,
I have an epicombo with bin num filtered by warehouse code. It works fine except that when the warehouse code field is empty I get all bins for all warehouses.
Any suggestions?
Joe
Hey there,
Any suggestions?
Joe
Is the expected function that you do not get any bins when you do not fill in a warehouse?
I do this with a BAQ to populate the combo. I have a warehouse combo that lists all the warehouses. I can filter in this BAQ to limit results if there are some warehouses I don’t want to be listed. Then I made a Bins BAQ that lists all of the bins from the warehouse selected. Here is the customization code for the dashboard side:
private void baqComboC1_Leave(object sender, System.EventArgs args)
if (baqComboC1.Value.ToString()!="")
getBins();
epiUltraComboC1.ForceRefreshList();
private void getBins()
cmbBins = (Ice.Lib.Framework.EpiUltraCombo)csm.GetNativeControlReference("886dc91a-429b-4b5b-b900-9e87438facfc");
DynamicQueryAdapter dqa = new DynamicQueryAdapter(oTrans);
dqa.BOConnect();
QueryExecutionDataSet qeds = dqa.GetQueryExecutionParametersByID("Bins");
qeds.ExecutionParameter.Clear();
qeds.ExecutionParameter.AddExecutionParameterRow("Ware", baqComboC1.Value.ToString(), "nvarchar", false, Guid.NewGuid(), "A");
dqa.ExecuteByID("Bins", qeds);
if (dqa.QueryResults.Tables["Results"].Rows.Count > 0)
cmbBins.DataSource = dqa.QueryResults.Tables["Results"];
cmbBins.DisplayMember = "WhseBin_BinNum";
cmbBins.ValueMember = "WhseBin_BinNum";
cmbBins.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
oTrans.NotifyAll();
else
MessageBox.Show("No Bins in Warehouse!");
With this method you need to setup the BAQs, but don't include parameters in the BAQ. The AddExecutionParameterRow() does that for you.
Can you change it to.
WarehouseCode = '?[BilletWarehouseCode_c]' OR WarehouseCode = ''
I tried these without effect:
WarehouseCode = ‘?[BilletWarehouseCode_c]’ OR WarehouseCode = ‘’
WarehouseCode = ‘?[BilletWarehouseCode_c]’ AND ‘?[BilletWarehouseCode_c]’ <> ‘’
It still returned all bins for all warehouses when the warehouse code was empty.
I already had another warehouse/bin combination working with a baq combo box on the bin number and a parameter linking to the dataset in the query like this:
Using this scheme, the query is good for only one code, because the criterion is hardcoded to a single column on the dataset. That’s why I was looking for a filter on the epicombobox.
In the end, I used another baqcombo, copied and modified the query, and went on to something else.
Thanks, folks.
Joe
