cool, thanks Tyler
Josh Serwe
Wisconsin Converting Inc.
Warehouse & Logistics Manager
(920)437-6400 x 330
Josh Serwe
(920)437-6400 x 330
----- Original Message -----
Sent: Friday, April 19, 2013 4:23:54 PM
Subject: [Vantage] RE: Clear Cycle Count Data
Just for future reference, there is a fix Epicor has to clear out the cycle counts.
Tyler Tisdale l IT Systems Administrator
ULTRAX Aerospace l 4200 NE Sun Court, Lee's Summit, MO 64064
t: 816-214-9999 l f: 816-214-9998 l e: ttisdale@... <mailto: ttisdale@... >
From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of Tyler Tisdale
Sent: Friday, April 19, 2013 3:17 PM
Thanks for taking some time. Always good to know I'm not doing something so simple wrong.
t: 816-214-9999 l f: 816-214-9998 l e: ttisdale@... <mailto:ttisdale%40ultraxinc.com><mailto: ttisdale@... <mailto:ttisdale%40ultraxinc.com>>
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Serwe
Sent: Friday, April 19, 2013 3:09 PM
Subject: RE: [Vantage] RE: Clear Cycle Count Data
Weird. I wish I could help but it sounds like you need to call support.
They were actually responsive to me when I had an issue last December so
hopefully they can help you out.
Josh Serwe
(920)437-6400 x 330
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
Of Tyler Tisdale
Sent: Friday, April 19, 2013 3:07 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
I was hoping it would be that easy, but when I try I get the following
error:
"The physical inventory warehouse control record was not found."
Detail:
Error Detail
Message: The physical inventory warehouse control record was not found.
Type: Error
Program: bo/CCCountCycle/CCCountCycle.p
Method: CancelPI
Table: CCWhsCtrl
Row:
Field:
t: 816-214-9999 l f: 816-214-9998 l e: ttisdale@... <mailto:ttisdale%40ultraxinc.com><mailto:ttisdale%40ultraxinc.com>
<mailto:ttisdale%40ultraxinc.com> <mailto: ttisdale@... <mailto:ttisdale%40ultraxinc.com><mailto:ttisdale%40ultraxinc.com>
<mailto:ttisdale%40ultraxinc.com> >
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Sent: Friday, April 19, 2013 3:02 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
You can't select "Cancel Physical Inventory"?
Josh Serwe
(920)437-6400 x 330
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf
Of Tyler Tisdale
Sent: Friday, April 19, 2013 2:52 PM
Sorry going blind on a Friday afternoon, right about there "Start Count
Sequence" is available, so it looks like they have not started it yet.
<mailto:ttisdale%40ultraxinc.com> <mailto:ttisdale%40ultraxinc.com>
Sent: Friday, April 19, 2013 2:49 PM
It must have been started, because under Actions there is a "Reverse State
Count" but it is grayed out.
<mailto:ttisdale%40ultraxinc.com><mailto: ttisdale@... <mailto:ttisdale%40ultraxinc.com><mailto:ttisdale%40ultraxinc.com>
<mailto:ttisdale%40ultraxinc.com> <mailto:ttisdale%40ultraxinc.com>>
Sent: Friday, April 19, 2013 2:46 PM
Subject: RE: [Vantage] Clear Cycle Count Data
Did you start the count sequence? If so, there is no going back.
Josh Serwe
(920)437-6400 x 330
Behalf
Of ultrax_tyler
Sent: Friday, April 19, 2013 2:44 PM
Subject: [Vantage] Clear Cycle Count Data
We are on 701 SQL and started to implement cycle counting and full
physical counting through Epicor. Something happened and I can not even
cancel the physical inventory. Does anyone know of a way to just clear
everything out manually? I was hoping maybe there was a conversion program
I could run.
