Clearing Ultragrids
Rob,
Thanks so much. That works perfectly!
Ross
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> When you want the grid to clear, i.e. on creation of a new record etc.
> try something like this..
> While ugdEpiCustom2.rows.count > 0
> ugdEpiCustom2.rows(0).delete(false)
> Rob Bucek
> -----Original Message-----
> Of Waffqle
> Sent: Tuesday, September 13, 2011 9:57 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Re: Clearing Ultragrids
> That would be my approach.
> On Tue, Sep 13, 2011 at 9:46 PM, rossh777 <ross.hughes3@...>
> wrote:
> > That is true. In my case I would like it to clear when I bring up a
> > new record.
> > Do I have to create a generic and empty dataset in these cases?
> > Thanks for your response,
> > Ross
> > --- In vantage@yahoogroups.com, Waffqle <waffqle@> wrote:
> > > I believe if you just rebind it to the new dataset it'll
> > > automatically remove the old stuff.
> > > On Tue, Sep 13, 2011 at 5:10 PM, rossh777 <ross.hughes3@> wrote:
> > > > While using UD100, I am getting data from the
> > > > orderdtlsearchadapter
> > (using
> > > > listlookup) on click of a button and pushing it to a grid with:
> > > > Grid.DataSource = dsData
> > > > After sending data to the grid, I hide some columns.
> > > > I want to clear the grid when going to the next UD100 record. I
> > > > can use
> > the
> > > > listchange event and use the following to clear the grid:
> > > > Grid.DataSource = Nothing
> > > > After this, whenever I try to push more data to the grid it gives
> > > > me 'parameter - key not found' errors among others. If I do the
> following:
> > > > Grid.ResetDisplayLayout ()
> > > > Grid.Layouts.Clear()
> > > > ...it will clear the grid and accept new data, but the next time I
> > assign
> > > > data it connects data to a child node (little triangle) in the
> > > > grid and eventually errors out.
> > > > What is the best way to clear an Ultragrid in this scenario, and
> > > > subsequently repopulate while avoiding this problem?
> > > > Thanks in advance,
> > > > Ross
> > > *Waffqle Driggers*
> > > *High End Dev, System Design, Profit Drinking
> > > *:: 904.962.2887*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
While using UD100, I am getting data from the orderdtlsearchadapter (using listlookup) on click of a button and pushing it to a grid with:
I want to clear the grid when going to the next UD100 record. I can use the listchange event and use the following to clear the grid:
After this, whenever I try to push more data to the grid it gives me 'parameter - key not found' errors among others. If I do the following:
...it will clear the grid and accept new data, but the next time I assign data it connects data to a child node (little triangle) in the grid and eventually errors out.
What is the best way to clear an Ultragrid in this scenario, and subsequently repopulate while avoiding this problem?
Thanks in advance,
Ross
I believe if you just rebind it to the new dataset it'll automatically
> Thanks in advance,
> Ross
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
That is true. In my case I would like it to clear when I bring up a new record.
Ross
> > Thanks in advance,
> > Ross
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> record.
> Ross
> (using
> the
> assign
> > > Thanks in advance,
> > > Ross
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@...*
> > *:: NO FAXES*
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Rob Bucek
Of Waffqle
> new record.
> Ross
> (using
> > > can use
> the
following:
> assign
> > > Thanks in advance,
> > > Ross
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@...*
> > *:: NO FAXES*
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
