"Click" Refresh button with code
Hi Simon,
Can you try this and let me now if it works.
                Private Sub epiButtonC1_Click(ByVal sender As Object, ByVal args As System.EventArgs)
                                Dim appController as UIApp.AppController = CType(oTrans, UIApp.AppController)
                                if Not(appController is nothing)
                                                appController.OnRefresh()
                                end if
                End Sub
Sent: Sunday, December 15, 2013 5:54 PM
Subject: [Vantage] RE: "Click" Refresh button with code
Ted,
Just wondering if you got this sorted out?  I have a similar problem, but when a user refreshes and we have groups on the dashboard it expands the tree to the first record in the BAQ based on the sort order.  My users really want the tree to remain collapsed on refresh, or even better to have it expanded to the show results where they are the Case Owner.
Previously I have not had any luck of actually loading a dashboard based on the who the user is logged in.  I believe the employeeid constant is only populated if you have MES and they clock in.  Can anyone confirm.
We are on 701 SQL
Cheers
Simon Hall
So far I am striking out with everything I have tried. I created a dashboard and want it to refresh after a certain allotted amount of time. For this I'm using a timer and inside the tick event i want to call the refresh button.
Here is what I have been trying but it does not work.
Dim frmDash As Epicor.Mfg.UI.FrameWork.UIApp.EpiHostForm = CType(csm.GetNativeControlReference("B564E070-3328-4f86-BF70-DD1C139CCB21"), Epicor.Mfg.UI.FrameWork.UIApp.EpiHostForm)
Dim methInfo As MethodInfo = frmDash.GetType().GetMethod("RefreshDB")
If Not (methInfo Is Nothing) Then
methInfo.Invoke(frmDash, Nothing)
End If
Dim mi As MethodInfo = GetType(Epicor.Mfg.UI.FrameWork.UIApp.EpiHostForm).GetMethod("RefreshDB", BindingFlags.NonPublic Or BindingFlags.Instance)
If Not mi Is Nothing Then
mi.Invoke(frmDash, New Object() {})
End If
Thanks for any help,
Ted
Ted, in other customizations I simply did a: oTrans.Refresh() and it did
wahat you wanted. Never tried it on Dashboards, however.
tkoch77
Sent: Thursday, June 28, 2012 11:51 AM
Subject: [Vantage] "Click" Refresh button with code
End If
End If
Ted
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2180 / Virus Database: 2437/5098 - Release Date: 06/28/12
Did you try the Refresh Interval under the Dashboard Query Properties?
120 = 2 minutes
9.05.607a
Miguel A. Santillan
Compass Components, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tkoch77
Sent: Thursday, June 28, 2012 8:51 AM
End If
End If
Ted
Didn't even think of that miguel, works well. The only thing that sucks is it collapses expanded groups. I dont think theres anything I can do about that though.
Thanks.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Thursday, June 28, 2012 11:56 AM
Subject: RE: [Vantage] "Click" Refresh button with code
120 = 2 minutes
9.05.607a
Miguel A. Santillan
End If
End If
Ted
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Well I am back to being stuck on this. Miguel's suggestion did work, but I am seeking more control over when refresh is actually called. Not sure how invoke the refresh button from a dashboard and I don't think there is a way to programmatically click a toolbar tool. Here is the code I have been playing with. Any help appreciated.
            mi.Invoke(MainController, New Object() {})
         End If
-Ted
Sent: Thursday, June 28, 2012 12:12 PM
Subject: Re: [Vantage] "Click" Refresh button with code
Thanks.
120 = 2 minutes
9.05.607a
Miguel A. Santillan
End If
End If
Ted
While looking through the ICE Customization Guide I stumbled across this bit of code on page 206 that is supposed to call the refresh button on the dashboard, but it does not work. Can anyone verify?
https://epicweb.epicor.com/doc/Docs/EpicorUserExpCust_UserGuide_905700_Part2of3.pdf
-Ted
> Â Â Â Â Â Â Â Â Â Dim mi As MethodInfo = GetType(Epicor.Mfg.UI.FrameWork.UIApp.EpiHostForm).GetMethod("RefreshDB", BindingFlags.NonPublic Or BindingFlags.Instance)
> Â Â Â Â Â Â Â Â Â If Not mi Is Nothing Then
> Â Â Â Â Â Â Â Â Â Â Â Â mi.Invoke(MainController, New Object() {})
> Â Â Â Â Â Â Â Â Â End If
> -Ted
> From: Ted Koch <tkoch77@...>
> Thanks.
> From: Miguel Santillan <msantillan@...>
> 120 = 2 minutes
> 9.05.607a
> Miguel A. Santillan
> End If
> End If
> Ted
Ted,
We are on 701 SQL
Cheers
Simon Hall
