Client timeout will be added to vantage 5.
rgors wrote:
rgors wrote:
> A sidebar question:
> I have been considering this utility to reduce license expense.
> However:
> A) what, if any, complaints and questions arise after implementation?
> B) Can you adjust the quantities of people to cut and/or the amount of
> "dead time" prior to cutting the user?
> C) Is there a cost and if so how much is it?
> D) Is it a hassle to install?
> THANK YOU VERY MUCH IN ADVANCE FOR YOUR RESPONSE!!!
> Rick
> MIS
> Osco
> Todd Hofert wrote:
> > I have been using Mike Podlins' client time out utility successfully
> > on v3.0
> > for sometime. I recently upgraded to v4.0 and need to use it on 4.0.
> > How do
> > I implement it for 4.0? Is it the same as 3.0, does it require a new
> > version?
> > PS, I posted to the group as I do not have Mike's e-mail address. My
> > apologies.
> > Thanks
> > Todd Hofert
> > Spartan Graphics, Inc.
> > (616)887-8243
> > eGroups Sponsor
> > We no longer allow attachments to files. To access/share Report
> > Files, please go to the following link:
> > http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you try it,
> > go to www.egroups.com, login and be sure to save your password, choose
> > My Groups, choose Vantage, then choose Files. If you save the
> > password, the link above will work the next time you try it.)
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
