Paul,
When this happens, our employees tell their supervisors and when
engineering is contacted, they are instructed to proceed with the job on
the floor (provided the part they are working on is not being changed)
and upon completion, shop supervision makes a labor adjustment, found
under Job Management/Job Adjustment/Labor Adjustment.
Steve
Sent: Tuesday, November 21, 2000 3:45 PM
To: 'vantage@egroups.com'
Subject: [Vantage] Clocking to a job while it is being
changed?
In a perfect world the engineering dept. will crank out a set of
drawings for a project which ends up on the shop floor after
which shop
employees use them to make a final product and in turn use
Vantage Data
Collection to clock their hours to the project.
However, my company is not the perfect company and we end up
doing some
redesigning of the project at the same it is being built. Our
problem is
that while an engineer is reworking certain aspects of a
machine, shop
employees are not able to clock their hours to the same project
because
the records in Vantage are locked by the engineer. The shop
employees
end up filling out little labor adjustment slips which tend to
really
annoy the HR dept.
Has anyone encountered this problem before, or could anyone give
me some
feedback on a work-around?
Thanks in advance!
Paul Siebers
-------------------------- eGroups Sponsor
We no longer allow attachments to files. To access/share Report
Files, please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you
try it, go to www.egroups.com, login and be sure to save your password,
choose My Groups, choose Vantage, then choose Files. If you save the
password, the link above will work the next time you try it.)
Steve
changed?
which shop
Vantage Data
doing some
problem is
machine, shop
because
employees
really
annoy the HR dept.
me some
Thanks in advance!
Paul Siebers
