Closed DMR - GL Transaction INS-DMR
OK. Both DMRs would have a INS-DMR trans & resulting GL debit (one offset appropriately by the dispositioned DMR action - that has a matching parttran record - & now the other Closed undispositioned DMR by a one sided journal entry - with no matching parttran record).
I guess where you are losing me (as I'm interested: We ran 5 yrs on Vantage 8 with inventory journal posting disabled & now live on E9 a little shy of a year, our comptroller is gaining enough confidence in people's execution of trans generating processes, he'd like to turn on inv journal posting May 1 when we start our new fuscal year).
Both INS-DMR transactions (& GL entries) had to be proceeded by an STK-INS transaction (& related GL entries - although perhaps as a portion of a summary posting) did they not?? (reducing your inventory on-hand twice as well - or was an ADJ-STK adjustment done to 'fix' one & correct o/h balances?)
If all records were written, accepting the (forced closed undispositioned) DMR back to stock (DMR-STK) would correct the inventory balance & the GL with an offsetting DMR resolution entry.
Or are you saying the network connectivity problem actually prevented the initial STK-INS parttran record to be written?
That would concern me. Client connectivity shouldn't impact full completion (or full rollback if failed) of all associated parttran, GL records & update of partbin.onhand values.
This is all occuring on the server (unless it too failed) & I'd be insisting Epicor support provide a fix.
Rob Brown
Versa Products
Sent from Yahoo Mail on Android
From:"'Chang, Chia' cchang@... [vantage]" <vantage@yahoogroups.com>
Date:Thu, Feb 12, 2015 at 5:03 PM
Subject:RE: [Vantage] Closed DMR - GL Transaction INS-DMR
<div id="ygrps-yiv-771713940ygrp-text">
  <p></p><div class="ygrps-yiv-771713940WordSection1"><p class="ygrps-yiv-771713940MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">The DMR is for Inventory.&nbsp; There is no adjustments needed since this is not a valid DMR.&nbsp; We closed this DMR out with full remaining quantities.</span></p><p class="ygrps-yiv-771713940MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></p><p class="ygrps-yiv-771713940MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">What happened was the user lost network connectivity and the system would no longer allow the user to complete the DMR.&nbsp; So the user created a new DMR completely.&nbsp; We are looking to remove any GL adjustments off the GL account for the invalid DMR.&nbsp; Anytime a DMR is created, it will create an INS-DMR debit transaction to the account regardless if you disposition it or not.&nbsp; The workaround was to do a manual one sided journal entry to bring the account back in balance.</span></p><p class="ygrps-yiv-771713940MsoNormal"><span
style=“font-size:11.0pt;color:#1F497D;”>
Sent: Tuesday, February 10, 2015 4:38 PM
To: vantage@yahoogroups com; vantage@yahoogroups com
Subject: Re: [Vantage] Closed DMR - GL Transaction INS-DMR
Reopen it and disposition it. Then do whatever adjustments are needed to
offset.
You didn't say what the source of the Nonconformance/DMR was (jobmtl, labor, inventory, PO receipt inspection) & the source determines your adjustment options.
Rob Brown
Versa Products
cchang@… [vantage]" <vantage@yahoogroups.com>
Date:Tue, Feb 10, 2015 at 1:56 PM
Subject:[Vantage] Closed DMR - GL Transaction INS-DMR
We created a DMR but decided to cancel it by closing it with open remaining quantities.  This created an INS-DMR transaction in the GL account when viewing it in the WIP/Recon report causing the GL account to be out of balance.  How do we cancel the DMR to balance the GL account?
</div>
<div class="ygrps-yiv-771713940yQTDBase ygrps-yiv-771713940yqt8047078582" id="ygrps-yiv-771713940yqt51469"><div style="color:#fff;height:0;"></div></div>
<!-- #ygrps-yiv-836110379 _filtered #ygrps-yiv-836110379 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-836110379 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-836110379 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-836110379 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-836110379 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-836110379 #ygrps-yiv-836110379 p.ygrps-yiv-836110379MsoNormal, #ygrps-yiv-836110379 li.ygrps-yiv-836110379MsoNormal, #ygrps-yiv-836110379 div.ygrps-yiv-836110379MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-836110379 a:link, #ygrps-yiv-836110379 span.ygrps-yiv-836110379MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-836110379 a:visited, #ygrps-yiv-836110379 span.ygrps-yiv-836110379MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-836110379 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-836110379 code
font-family:“Courier New”;}
#ygrps-yiv-836110379 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-836110379 tt
#ygrps-yiv-836110379 span.ygrps-yiv-836110379HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-836110379 p.ygrps-yiv-836110379attach, #ygrps-yiv-836110379 li.ygrps-yiv-836110379attach, #ygrps-yiv-836110379 div.ygrps-yiv-836110379attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-836110379 p.ygrps-yiv-836110379bold, #ygrps-yiv-836110379 li.ygrps-yiv-836110379bold, #ygrps-yiv-836110379 div.ygrps-yiv-836110379bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-836110379 p.ygrps-yiv-836110379green, #ygrps-yiv-836110379 li.ygrps-yiv-836110379green, #ygrps-yiv-836110379 div.ygrps-yiv-836110379green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-836110379 p.ygrps-yiv-836110379replbq, #ygrps-yiv-836110379 li.ygrps-yiv-836110379replbq, #ygrps-yiv-836110379 div.ygrps-yiv-836110379replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-836110379 p.ygrps-yiv-836110379ad, #ygrps-yiv-836110379 li.ygrps-yiv-836110379ad, #ygrps-yiv-836110379 div.ygrps-yiv-836110379ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-836110379 p.ygrps-yiv-836110379underline, #ygrps-yiv-836110379 li.ygrps-yiv-836110379underline, #ygrps-yiv-836110379 div.ygrps-yiv-836110379underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-836110379 span.ygrps-yiv-836110379yshortcuts
#ygrps-yiv-836110379 p.ygrps-yiv-836110379ad1, #ygrps-yiv-836110379 li.ygrps-yiv-836110379ad1, #ygrps-yiv-836110379 div.ygrps-yiv-836110379ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-836110379 p.ygrps-yiv-836110379ad2, #ygrps-yiv-836110379 li.ygrps-yiv-836110379ad2, #ygrps-yiv-836110379 div.ygrps-yiv-836110379ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-836110379 p.ygrps-yiv-836110379underline1, #ygrps-yiv-836110379 li.ygrps-yiv-836110379underline1, #ygrps-yiv-836110379 div.ygrps-yiv-836110379underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-836110379 span.ygrps-yiv-836110379yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-836110379 span.ygrps-yiv-836110379yshortcuts2
font-weight:normal;}
#ygrps-yiv-836110379 span.ygrps-yiv-836110379EmailStyle34
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-836110379 .ygrps-yiv-836110379MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-836110379 div.ygrps-yiv-836110379WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-836110379 ol
{margin-bottom:0in;}
#ygrps-yiv-836110379 ul
Reopen it and disposition it. Then do whatever adjustments are needed to offset.
Rob Brown
Versa Products
<div id="ygrps-yiv-263853795ygrp-text">
  <p></p><div class="ygrps-yiv-263853795WordSection1"><p class="ygrps-yiv-263853795MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">We created a DMR but decided to cancel it by closing it with open remaining quantities.&nbsp; This created an INS-DMR transaction in the GL account when viewing it in the WIP/Recon report causing the GL account to be out of balance.&nbsp; How do we cancel the DMR to balance the GL account?</span></p></div>
</div>
