# 'CLOSED' ShipHead.ShipStatus **Category:** [Epicor ERP 10](https://www.epiusers.help/c/e10/5) **Created:** 2016-11-29 15:38 UTC **Views:** 2005 **Replies:** 4 **URL:** https://www.epiusers.help/t/closed-shiphead-shipstatus/36447 --- ## Post #1 by @ckrusen What is a "Closed" ShipHead ShipStatus? Data Dict says Ship Status can be one of: > Open, Closed, Freighted, Void, Staged, or Shipped Just curious to know if I need to be handle that type in my automated emailing of Packers. Currently, the trigger is ShipHead.ShipStatus changing from anything to "Shipped" OR (ShipHead.TrackingNum changing from anything to anything AND ShipHead.ShipStatus = Shipped") The second part is to resend the packer should the Shipping Num change after it is marked shipped. --- ## Post #2 by @mjfwagner Normally if you are using Phantom packs you need to close the pack (after getting weights) so that it can be shipped. Also used by Insite Manifest as well If you are not doing either one you should be fine as marking the pack as shipped and later when it invoices it will auto update to invoiced status Mark Wagner Sr. Partner Capstone Alliance Partners 888.597.2227 Ext. 71 <888.597.2227%20Ext.%20714>2 | 904.412.6847 (cell) | www.capstoneap.com --- ## Post #3 by @ckrusen I noticed that the Cust Shipment display can show 'Invoiced', but that isn't mentioned in the data dictionary. A quick check of the ShipHead table shows no records with a ShipStatus of "Invoiced", even though the Cust Shipment displays "Invoiced". I don't think "Invoiced" will ever be a real condition of ShipStatus. --- ## Post #4 by @Manasa If you use any of the manifest shipping programs, you have to CLOSE a pack slip before you can FREIGHT it….if you don’t use these then it is irrelevant to you. That is the quick version…. M. Manasa Reddy P: 703.471.7145 x454 manasa@euclidsys.com --- ## Post #5 by @Randy ShipHead.Invoiced = True is the toggle for "Invoiced" --- **Canonical:** https://www.epiusers.help/t/closed-shiphead-shipstatus/36447 **Original content:** https://www.epiusers.help/t/closed-shiphead-shipstatus/36447
