Here is the Job/Asm/Opr barcode that I'm using for MES:
"*" + Trim({OPENJOBS_VIEW.JobNum}) + "$I" +
trim(totext({JobAsmbl.AssemblySeq},0)) + "$I" +
trim(totext({JobOper.OprSeq},0)) + "$I" + "*"
We also have Symbol LS2208 scanners. I had to experiment with the
settings to get it to work the tabs. I narrowed it down to about 50
parameters. It only takes a minute or so to scan them all in so I
haven't bothered to narrow it down further.
--- In vantage@yahoogroups.com, "Bruce Ordway" <cooner_55421@...> wrote:
> --- In vantage@yahoogroups.com, Todd Caughey <caugheyt@> wrote:
> > Internally I would use Code 39. Much easier to deal with. Code
> 128 is mostly for automated material handling systems to route
> materials to the correct place.
> Hi Todd,
> I only worked with the default Code 39 a little bit & it's been a
> long time.
> I was able to append tab characters in a bar code OK.
> = "*" & [Job] & "$I*"
> I only tried for a few hours, but, I never did find a way to
> concatenate "JobNum", tab, "AsmNum", tab , "Opr", tab.
> I was using a Symbol LS2208.
> Do have sample concatenation string for Code 39?
> Thanks,
> Bruce
