Code for calc_serialnumber on the Transfer Order Packing Slip
Thanks!
I figured that I could get to it if I had the SDK, unfortunately, we do not. Does anyone that could help?
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> We are on 8.03 and I am not familiar with the transfer order packing slip, but from my experience with other data definitions that have a Calc_Serialnumber I can guess that this is a list of serial numbers. I have seen this field in the EDIArFrm data definition for EDI. It is a comma delineated list of serial numbers associated with the line items on the invoice. Probably something similar in your case.
> Also note that while this is a calculated field and the code for it is generally not visible to the general user, I believe that you can get to it (and create others) if you have the SDK.
> From: Jen Triftshauser <jennifertriftshauser@...>
> To: vantage@yahoogroups.com
> Sent: Tue, February 2, 2010 8:08:26 AM
> Subject: [Vantage] code for calc_serialnumber on the Transfer Order Packing Slip
> ÂÂ
> Epicor 9.04.504c
> All,
> I have been asked to put serial numbers on the Transfer Order Packing Slip. I've noticed that on the Crystal Form, there is a field called:
> TFShipDtl.Calc_ Serialnumber
> This calculation is embedded in the Epicor code, and is not visible to the general user. (I've asked our Epicor Consultant)
> Does anyone know what this calculation is? I'm specifically looking for the tables the serial number is pulled from, in hopes that I can write something simpler.
> Any info is much appreciated!
> TIA
Epicor 9.04.504c
All,
TFShipDtl.Calc_Serialnumber
TIA
Â
Epicor 9.04.504c
All,
TIA
