Code for Creating ADO XML Persisted recordset
Thad,
I wanted to ask a question about ADO Parameters in Visual Basic 6.
When I work with a recordset created by CreateParameter method I cannot
delete a record in that recordset. Right now the program has to go through
all the records and check each record to see if it matches the criteria.
With parameters it is lot faster but doesn't wont to delete a record.
Mike Tonoyan / MIS Manager
All American Products Co.
1135 Aviation Place
San Fernando, CA 91340
USA
Tel.: 818-361-0059 Ext.: 246
Fax 818-898-2236
E-mail: miket@...
Web: www.allamericanproducts.com
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, May 23, 2002 1:47 PM
Subject: RE: [Vantage] Code for Creating ADO XML Persisted recordset
I also neglected to mention that I've been doing a bit of R&D with Visual
Studio .NET. Once that becomes my primary development environment (when we
get our new vantage and intranet servers) having XML-Based exports will be a
huge plus.
I plan on setting things up so that I can launch my progress exports from
ASP pages, read the XML files, and load them into Crystal .NET reports.
I would use Access databases, but I wanted to allow multiple users to have
multiple instances of the same report (such as a bom) loaded at the same
time. Facilitating that in a multi-user environment required writing code
to copy blank database templates to the user's machine, and writing
additional code to accomodate for multiple linked csv files at the same
time.
Keeping the data encapsulated in One XML File, instead of an Access MDB and
a linked CSV file makes the system alot easier for me to manage.
However, unless you are willing to do a lot more coding than you already
are, there's not much of a need to make the jump to XML quite yet.
Thaddeus Jacobs
Information Solutions Developer
Kinematic Automation, Inc.
mailto:tjacobs@...
Sent: Thursday, May 23, 2002 12:44 PM
Subject: Re: [Vantage] Code for Creating ADO XML Persisted recordset
Thanks for the info, Thad. On a somewhat related note: I did get the ADO
connection in Crystal to recognize my .csv exports properly. However, I
found ADO to be quite a bit slower than connecting the .csv files to reports
through Access. It's a bit harder to set up in Access, but once set up, it
reads the records MUCH faster (on large .csv files it's noticable anyway).
Also, with Access you can manually select the data type if it doesn't
interpret correctly by itself. For instance, when using an Outer-Join in
the export, if a record doesn't exist Progress puts a "?" in the field.
This is fine, but if that happens in numeric fields then Access thinks the
field is a text field. Manually setting it to Integer or Double will allow
Crystal to correctly find it as a number.
Troy Funte
Liberty Electronics
To: 'vantage@yahoogroups.com'
Sent: Thursday, May 23, 2002 3:28 PM
For me, XML is an alternative to CSV exports.
I needed an alternative, because CSV doesn't hold any schema information
(as
in the size of the fields, their datatypes, etc...)
Of course, the Jet/Access drivers can import a csv file and can guess(with
fairly good accuracy) the datatype of the csv column, based on the
characters it contains. However, on one of my vendor transaction reports,
datatypes were being interpreted inconsistently by the Jet drivers.
For programmers using ADO (Advanced Data Objects), this XML format is nice
because you don't have to use an ODBC or OLEDB driver to access the data,
thus improving reliability and performance.
However, Crystal reports doesn't natively support XML files until version
8.5.
XML is of minimal value to most vantage users, but for a few of us
programmers who need to write progress exports to use in external
applications (such as crystal reports), XML is definitely a viable option.
An excerpt from:
http://www.xmlfiles.com/xml/
"XML can be used to exchange data:
In the real world, computer systems and databases contain data in
incompatible formats. One of the most time consuming challenges for
developers has been to exchange data between such systems....Converting
the
data to XML can greatly reduce this complexity and create data that can be
read by different types of applications."
All that said, CSV exports still take less code to write, and are still my
method of choice in some instances.
Thaddeus Jacobs
mailto:tjacobs@...
Sent: Thursday, May 23, 2002 12:07 PM
Thad,
Lots of questions I could ask, but starting with: What's an XML file
and
why would I want to use it?
Troy Funte
Liberty Electronics
To: 'Scandale, Matt' ; 'api@...' ; 'peg@...' ;
Sent: Thursday, May 23, 2002 1:36 PM
Subject: [Vantage] Code for Creating ADO XML Persisted recordset
Here's some code for creating an XML file from progress. The format
used
is ADO Persisted recordset (urn:schemas-microsoft-com:rowset).
The resulting file can be loaded into an ADO recordset by using the
recordset's OPEN method.
PEG API Members:
Though this post does not directly relate to API, it does provide a
viable
alternative to COM for creating a temporary database file.
Any questions or comments are welcome.
Thaddeus Jacobs
mailto:tjacobs@...
/************BEGIN CUSTOMERSXML.P*********/
{xml.i}
output stream xml to c:\test.xml.
run BeginSchema.
run AddFieldToSchema("CustID", "CHAR").
run AddFieldToSchema("CustName", "CHAR").
run AddFieldToSchema("Phone", "CHAR").
run AddFieldToSchema("Fax", "CHAR").
run AddFieldToSchema("Address1", "CHAR").
run AddFieldToSchema("Address2", "CHAR").
run AddFieldToSchema("Address3", "CHAR").
run AddFieldToSchema("City", "CHAR").
run AddFieldToSchema("State", "CHAR").
run AddFieldToSchema("ZIP", "CHAR").
run AddFieldToSchema("Country", "CHAR").
run AddFieldToSchema("CustNum", "NUMBER").
run EndSchema.
run BeginRowSet.
for each customer no-lock where company = "001" by name:
run Addrow.
run UpdateStringField("CustID", custid).
run UpdateStringField("CustName", name).
run UpdateStringField("Phone", phone).
run UpdateStringField("Fax", fax).
run UpdateStringField("Address1", address1).
run UpdateStringField("Address2", address2 ).
run UpdateStringField("Address3", address3).
run UpdateStringField("City", city).
run UpdateStringField("State", state).
run UpdateStringField("ZIP", zip).
run UpdateStringField("Country", country ).
run UpdateNumberField("CustNum", CustNum).
run EndRow.
end.
run endrowset.
output stream xml close.
/* To test the integrity of the ADO Persisted
XML recordset at design time:*/
def var rs as com-handle no-undo.
create "adodb.recordset" rs.
rs:open("c:\test.xml",,,,).
rs:close.
release object rs.
/**********END CUSTOMERSXML.P*********/
/************BEGIN XML.I*********/
/*The purpose of this library is to automate the creation of an XML
file.
The current XML format I'm using is ADO persisted recordset,
but the functions could be rewritten to accommodate
other XML formats, without having to change the calling code.
def var fieldcount as integer no-undo.
def stream xml.
procedure BeginSchema:
put stream xml unformatted
"<xml xmlns:s=""uuid:BDC6E3F0-6DA3-11d1-A2A3-00AA00C14882""
xmlns:dt=""uuid:C2F41010-65B3-11d1-A29F-00AA00C14882""
xmlns:rs=""urn:schemas-microsoft-com:rowset""
xmlns:z=""#RowsetSchema"">
<s:Schema id=""RowsetSchema"">
<s:ElementType name=""row"" content=""eltOnly""
rs:updatable=""true"">".
end.
procedure AddFieldToSchema:
define input parameter FieldName as char no-undo.
define input parameter FieldType as char no-undo.
def var dt as char no-undo.
/*these data type strings where simply copied from ADO persisted
recordsets
from a SQL database. More datatype options
should be added as necessary*/
if FieldType = "CHAR" then
dt = "<s:datatype dt:type=""string"" dt:maxLength=""255""
rs:precision=""0"" rs:fixedlength=""true"" />".
else if FieldType = "NUMBER" then
dt = "<s:datatype dt:type=""float"" dt:maxLength=""8""
rs:precision=""15"" rs:fixedlength=""true""/>".
else if FieldType = "CURRENCY" then
dt = "<s:datatype dt:type=""number"" rs:dbtype=""currency""
dt:maxLength=""8"" rs:precision=""19"" rs:fixedlength=""true""/>".
else if FieldType = "DATE" then
dt = "<s:datatype dt:type=""dateTime"" rs:dbtype=""timestamp""
dt:maxLength=""16"" rs:scale=""0"" rs:precision=""16""
fieldcount = fieldcount + 1.
"<s:AttributeType name="""
FieldName
""" rs:number="""
string(FieldCount)
""" rs:nullable=""true"" rs:write=""true"">"
dt
"</s:AttributeType>".
end.
procedure EndSchema:
"<s:extends type=""rs:rowbase"" />
</s:ElementType>
</s:Schema>".
end.
procedure BeginRowSet:
"<rs:data>
<rs:insert>".
end.
Procedure AddRow:
put stream xml unformatted "<z:row".
end.
Procedure UpdateStringField:
define input parameter FieldValue as char no-undo.
/*Here's some code to replace some special XML characters with their
corresponding codes.
If you are certain the field does not contain the offending
characters, you could potentially delete the
replace statements for a modest performance increase*/
fieldvalue = replace(fieldvalue, "&", "&").
fieldvalue = replace(fieldvalue, """", """).
fieldvalue = replace(fieldvalue, "'", "'").
fieldvalue = replace(fieldvalue, "<", "<").
fieldvalue = replace(fieldvalue, ">", ">").
fieldvalue = replace(fieldvalue, "æ", "+/-").
fieldvalue = replace(fieldvalue, "°", "deg").
" " fieldname "=""" fieldvalue """".
end.
Procedure UpdateDateField:
define input parameter DateValue as date.
put stream xml unformatted " " fieldname "=""".
put stream xml year (DateValue) FORMAT "9999".
put stream xml "-".
put stream xml month (DateValue) FORMAT "99".
put stream xml "-".
put stream xml day (DateValue) FORMAT "99".
put stream xml "T00:00:00""".
end.
Procedure UpdateNumberField:
define input parameter FieldValue as decimal no-undo.
" " fieldname "=""" string(fieldvalue) """".
end.
Procedure EndRow:
put stream xml unformatted "/>".
end.
procedure EndRowSet:
"</rs:insert>
</rs:data>
</xml>".
end.
/*END XML.I*/
Yahoo! Groups Sponsor
ADVERTISEMENT
and
have
ADVERTISEMENT
Here's some code for creating an XML file from progress. The format used
PEG API Members:
Though this post does not directly relate to API, it does provide a viable
Thaddeus Jacobs
mailto:tjacobs@...
{xml.i}
run BeginSchema.
run EndSchema.
run BeginRowSet.
run Addrow.
run EndRow.
end.
run endrowset.
rs:close.
release object rs.
/*The purpose of this library is to automate the creation of an XML file.
def stream xml.
end.
/*these data type strings where simply copied from ADO persisted recordsets
FieldName
""" rs:number="""
string(FieldCount)
dt
end.
</s:ElementType>
</s:Schema>".
end.
"<rs:data>
<rs:insert>".
end.
Procedure AddRow:
end.
end.
put stream xml "-".
put stream xml "-".
end.
end.
Procedure EndRow:
end.
"</rs:insert>
</rs:data>
</xml>".
end.
/*END XML.I*/
Thad,
Lots of questions I could ask, but starting with: What's an XML file and why would I want to use it?
Troy Funte
Liberty Electronics
To: 'Scandale, Matt' ; 'api@...' ; 'peg@...' ; 'vantage@yahoogroups.com'
PEG API Members:
Thaddeus Jacobs
mailto:tjacobs@...
{xml.i}
run BeginSchema.
run EndSchema.
run BeginRowSet.
run Addrow.
run EndRow.
end.
run endrowset.
rs:close.
release object rs.
def stream xml.
end.
FieldName
""" rs:number="""
string(FieldCount)
dt
end.
</s:ElementType>
</s:Schema>".
end.
"<rs:data>
<rs:insert>".
end.
Procedure AddRow:
end.
end.
put stream xml "-".
put stream xml "-".
end.
end.
Procedure EndRow:
end.
"</rs:insert>
</rs:data>
</xml>".
end.
/*END XML.I*/
ADVERTISEMENT
I needed an alternative, because CSV doesn't hold any schema information (as
8.5.
An excerpt from:
developers has been to exchange data between such systems....Converting the
Thaddeus Jacobs
mailto:tjacobs@...
Thad,
Troy Funte
Liberty Electronics
PEG API Members:
Thaddeus Jacobs
mailto:tjacobs@...
{xml.i}
run BeginSchema.
run EndSchema.
run BeginRowSet.
run Addrow.
run EndRow.
end.
run endrowset.
rs:close.
release object rs.
def stream xml.
end.
recordsets
FieldName
""" rs:number="""
string(FieldCount)
dt
end.
</s:ElementType>
</s:Schema>".
end.
"<rs:data>
<rs:insert>".
end.
Procedure AddRow:
end.
end.
put stream xml "-".
put stream xml "-".
end.
end.
Procedure EndRow:
end.
"</rs:insert>
</rs:data>
</xml>".
end.
/*END XML.I*/
ADVERTISEMENT
Thanks for the info, Thad. On a somewhat related note: I did get the ADO connection in Crystal to recognize my .csv exports properly. However, I found ADO to be quite a bit slower than connecting the .csv files to reports through Access. It's a bit harder to set up in Access, but once set up, it reads the records MUCH faster (on large .csv files it's noticable anyway). Also, with Access you can manually select the data type if it doesn't interpret correctly by itself. For instance, when using an Outer-Join in the export, if a record doesn't exist Progress puts a "?" in the field. This is fine, but if that happens in numeric fields then Access thinks the field is a text field. Manually setting it to Integer or Double will allow Crystal to correctly find it as a number.
Troy Funte
Liberty Electronics
8.5.
An excerpt from:
Thaddeus Jacobs
mailto:tjacobs@...
Thad,
Troy Funte
Liberty Electronics
PEG API Members:
Thaddeus Jacobs
mailto:tjacobs@...
{xml.i}
run BeginSchema.
run EndSchema.
run BeginRowSet.
run Addrow.
run EndRow.
end.
run endrowset.
rs:close.
release object rs.
def stream xml.
end.
recordsets
FieldName
""" rs:number="""
string(FieldCount)
dt
end.
</s:ElementType>
</s:Schema>".
end.
"<rs:data>
<rs:insert>".
end.
Procedure AddRow:
end.
end.
put stream xml "-".
put stream xml "-".
end.
end.
Procedure EndRow:
end.
"</rs:insert>
</rs:data>
</xml>".
end.
/*END XML.I*/
ADVERTISEMENT
ADVERTISEMENT
huge plus.
time.
Thaddeus Jacobs
mailto:tjacobs@...
Troy Funte
Liberty Electronics
(as
8.5.
An excerpt from:
the
Thaddeus Jacobs
mailto:tjacobs@...
Thad,
and
Troy Funte
Liberty Electronics
used
PEG API Members:
viable
Thaddeus Jacobs
mailto:tjacobs@...
{xml.i}
run BeginSchema.
run EndSchema.
run BeginRowSet.
run Addrow.
run EndRow.
end.
run endrowset.
rs:close.
release object rs.
file.
def stream xml.
end.
recordsets
FieldName
""" rs:number="""
string(FieldCount)
dt
end.
</s:ElementType>
</s:Schema>".
end.
"<rs:data>
<rs:insert>".
end.
Procedure AddRow:
end.
end.
put stream xml "-".
put stream xml "-".
end.
end.
Procedure EndRow:
end.
"</rs:insert>
</rs:data>
</xml>".
end.
/*END XML.I*/
ADVERTISEMENT
and
have
ADVERTISEMENT
Whoa. You are light-years ahead of me on this stuff. You're saying all the words that I would love to learn about... but alas. Gotta keep focused on the fires at hand. But I'll know who to ask when my pallette clears off.
Thanks Thad.
Troy
Sent: Thursday, May 23, 2002 4:47 PM
huge plus.
time.
Thaddeus Jacobs
mailto:tjacobs@...
Troy Funte
Liberty Electronics
(as
8.5.
An excerpt from:
the
Thaddeus Jacobs
mailto:tjacobs@...
Thad,
and
Troy Funte
Liberty Electronics
used
PEG API Members:
viable
Thaddeus Jacobs
mailto:tjacobs@...
{xml.i}
run BeginSchema.
run EndSchema.
run BeginRowSet.
run Addrow.
run EndRow.
end.
run endrowset.
rs:close.
release object rs.
file.
def stream xml.
end.
recordsets
FieldName
""" rs:number="""
string(FieldCount)
dt
end.
</s:ElementType>
</s:Schema>".
end.
"<rs:data>
<rs:insert>".
end.
Procedure AddRow:
end.
end.
put stream xml "-".
put stream xml "-".
end.
end.
Procedure EndRow:
end.
"</rs:insert>
</rs:data>
</xml>".
end.
/*END XML.I*/
ADVERTISEMENT
and
have
ADVERTISEMENT
ADVERTISEMENT
