Thanks guys.
I will see what I can do. Could I ask another question...
Instead of querying the table twice, could I query it once to take
all of the necessary joboper records and place this in an array or a
select list. Then use this to as the basis, or am I going on a
tangent.
Thanks again.
--- In vantage@yahoogroups.com, "Chris Robisch" <blue.wine@v...>
tangent.
Thanks again.
wrote:
> Also select also with the "company" field on almost every file inVantage.
>an index
> Progress uses a binary search method if you specify all fields of
> in order. Otherwise, a sequential and much slower search is used.way to make
> From: "brychanwilliams" <brychanw@h...>
> To: <vantage@yahoogroups.com>
> Sent: Wednesday, July 20, 2005 1:36 PM
> Subject: [Vantage] Code Newbie > BAM Progress Code . Is there a
> this faster?labor
> > Hi,
> > I have written a bit of basic code to create an alert based on
> > qtys at previous operations under some conditions.quicker.
> > I'm quite new to this but is there a way make this execute
> > It only takes a couple of seconds but I would like it to work**
> > quicker.
> > Any help would be great.
> > Vantage 6.1
> > Thanks
> > ******/<> "B"
> > {ud/GlbAlert.i &TableName = "LaborDtl"}
> > DEFINE VARIABLE internaljobnum AS CHARACTER NO-UNDO.
> > DEFINE VARIABLE currentqtycompleted as Decimal NO-UNDO.
> > DEFINE VARIABLE runqty as Decimal NO-UNDO.
> > DEFINE VARIABLE currentlaborqty as Decimal NO-UNDO.
> > DEFINE VARIABLE CurrentOp as integer NO-UNDO.
> > DEFINE VARIABLE priorqtycompleted as Decimal NO-UNDO.
> > DEFINE VARIABLE prioroprseq as integer NO-UNDO.
> > DEFINE VARIABLE priorworkcode AS CHARACTER NO-UNDO.
> > Currentop = LaborDtl.OprSeq.
> > FIND MFGSYS.JobOper
> > WHERE (MFGSYS.JobOper.JobNum = Labordtl.JobNum) and
> > (MFGSYS.JobOper.assemblyseq = Labordtl.assemblyseq) and
> > (MFGSYS.JobOper.Oprseq = Labordtl.OprSeq) NO-LOCK NO-ERROR.
> > IF NOT AVAILABLE MFGSYS.JobOper THEN DO:
> > RETURN "CANCEL SEND".
> > RETURN .
> > END.
> > currentqtycompleted = MFGSYS.JobOper.QtyCompleted.
> > mainloop:
> > REPEAT:
> > Currentop = (Currentop - 1).
> > FIND MFGSYS.JobOper
> > WHERE MFGSYS.JobOper.JobNum = Labordtl.JobNum and
> > MFGSYS.JobOper.assemblyseq = Labordtl.assemblyseq and
> > MFGSYS.JobOper.OprSeq = Currentop NO-LOCK NO-ERROR.
> > IF AVAILABLE MFGSYS.JobOper THEN DO:
> > IF MFGSYS.JobOper.WCCode <> "CORE" AND
> > MFGSYS.JobOper.QtyPer = 1 AND MFGSYS.JobOper.LaborEntryMethod
> > THEN DO:MFGSYS.JobOper.QtyCompleted.
> > priorworkcode = MFGSYS.JobOper.WCcode.
> > priorqtycompleted =
> > prioroprseq = MFGSYS.JobOper.OprSeq.priorqtycompleted)
> > IF (currentqtycompleted >
> > THEN DO:string
> > Message "Prior Operation Seq - " +
> > (prioroprseq)You must
> > + " - Prior Wrk Code - " + string
> > (priorworkcode) +
> > " - QtyPer - " + string
> > (MFGSYS.JobOper.QtyPer) +
> > " - Prior Qty Completed " + string
> > (priorqtycompleted) View-as alert-box information buttons ok.
> > END.
> > ELSE DO:
> > LEAVE mainloop.
> > END.
> > LEAVE mainloop.
> > END.
> > END.
> > IF Currentop = 0 THEN DO:
> > LEAVE mainloop.
> > END.
> > END.
> > Return.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> > have already linked your email address to a yahoo id to enableaccess. )
> > (1) To access the Files Section of our Yahoo!Group for ReportBuilder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Links
