Coding Part Adapter into Sales Order Entry...need help
Thanks Ross. I will follow the example.
Best Regards,
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@...
607-754-9187 ext. 3078
www.ergpower.com
_____
Ross Hughes
Sent: Thursday, October 15, 2009 7:24 PM
Subject: Re: [Vantage] coding Part Adapter into Sales Order Entry...need
help
Herby,
There is a simpler approach.
You should be able to create a foreign key view (through data tools)
to the part table and then just reference part master data like the
other fields in so entry. The new view name will be whatever you
named your fkv.
Ross
On Oct 15, 2009, at 6:10 PM, "Herby Dallard" <hdallard@ergpower.
<mailto:hdallard%40ergpower.com> com>
wrote:
> Hello all.
> In the sales order entry form I would like to reference a field of
> the part
> maintenance table. As you may know, part maintenace is not already
> loaded in
> Sales Order entry form. I know I need to create an adapter to
> partadapter;
> however, I am unsure of how to pull in the corresponding row in part
> adaptor
> (part maintenance) that will based on the match up of part.partnum to
> orderdtl.partnum. Also, I am unsure of what event to use.
> Please help.
> Thanks in advance.
> Here is my code:
> Private Sub OrderDtl_AfterFieldChange(ByVal sender As object, ByVal
> args As
> DataColumnChangeEventArgs) Handles OrderDtl_Column.ColumnChanged
> '// ** Argument Properties and Uses **
> '// args.Row("[FieldName]")
> '// args.Column, args.ProposedValue, args.Row
> 'Add Event Handler Code
> Dim compAdapt As PartAdapter = New PartAdapter(SalesOrderForm)
> compAdapt.BOConnect()
> Dim partnumber as String = SalesOrderForm.Session.PartNum
> Dim ret As Boolean = compAdapt.GetByID(partnumber)
> Dim retdesigntype As String =
> CompAdapt.PartData.Tables("Part").Rows(0)("Character05") '//this
> line is
> incorrect and I don't know how to fix it!
> Select Case args.Column.ColumnName
> Case "PartNum"
> txtEpiCustom2.value = retdesigntype '// this line
> is to
> take the value of retdesigntype = part.character05
> '// based on part.partnum = orderdtl.partnum
> Case Else
> End Select
> compAdapt.Dispose()
> End Sub
> Best Regards,
> Herby Dallard
> hdallard@ergpower. <mailto:hdallard%40ergpower.com> com
> www.ergpower.com
> _____
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> Behalf Of
> Mark Wagner
> Sent: Tuesday, October 13, 2009 8:11 AM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: RE: [Vantage] 408b - Printing Issues
> Interesting, thanks for the tip!
> --- On Tue, 10/13/09, Mark Wonsil <mark_wonsil@
> <mailto:mark_wonsil%40yahoo.com> yahoo.com> wrote:
> From: Mark Wonsil <mark_wonsil@ <mailto:mark_wonsil%40yahoo.com> yahoo.com
> Date: Tuesday, October 13, 2009, 7:23 AM
> vantage@yahoogroups .com wrote:
>> Mark, I havent heard that about 504. If you get that message
>> do you change the default report style back to the standard
>> and then reset to the modified report style again?
> Yes, make sure to save it both times too.
> Mark W.
> must have already linked your email address to a yahoo id to enable
> access. )
> Builder and Crystal Reports and other 'goodies', please goto:
http://groups. <http://groups.yahoo.com/group/vantage/files/>
> (2) To search through old msg's goto: http://groups.
http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>
yahoo.com/group/vantage/linksYahoo!
> Groups Links
Is anyone else getting occasional errors when they try to print in
version 408B. The errors are numbers 7224, 7249 & 7209. Anyone have
any insight on what could be causing these errors? Support wants me to
run conversion 130 again but I figured I'd see if anyone out here might
know what's the main cause of the errors.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
> here might know what's the main cause of the errors.
Those error numbers are not helpful to me but if in the Details you see a
message that says, "Constraints Violation" then the trick is to reset the
defaults on your Report Styles. 408 seems to share some code with 504, so it
may be the same thing that happened to us and other 9.04 users.
Mark W.
Mark, I havent heard that about 504. If you get that message do you change the default report style back to the standard and then reset to the modified report style again?
Date: Tuesday, October 13, 2009, 6:44 AM
Â
Mark W.
Mark W.
Â
Mark W.
Hello all.
In the sales order entry form I would like to reference a field of the part
maintenance table. As you may know, part maintenace is not already loaded in
Sales Order entry form. I know I need to create an adapter to partadapter;
however, I am unsure of how to pull in the corresponding row in part adaptor
Please help.
Thanks in advance.
Here is my code:
Private Sub OrderDtl_AfterFieldChange(ByVal sender As object, ByVal args As
CompAdapt.PartData.Tables("Part").Rows(0)("Character05") '//this line is
Case "PartNum"
txtEpiCustom2.value = retdesigntype '// this line is to
Case Else
End Select
compAdapt.Dispose()
End Sub
Best Regards,
Herby Dallard
hdallard@...
www.ergpower.com
_____
Mark Wagner
From: Mark Wonsil <mark_wonsil@ <mailto:mark_wonsil%40yahoo.com> yahoo.com>
Mark W.
Herby,
named your fkv.
Ross
On Oct 15, 2009, at 6:10 PM, "Herby Dallard" <hdallard@...>
wrote:
> Hello all.
> the part
> loaded in
> partadapter;
> adaptor
> Please help.
> Thanks in advance.
> Here is my code:
> args As
> line is
> Case "PartNum"
> is to
> Case Else
> End Select
> compAdapt.Dispose()
> End Sub
> Best Regards,
> Herby Dallard
> hdallard@...
> www.ergpower.com
> _____
> Behalf Of
> Mark Wagner
> Mark W.
> access. )
> Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo!
> Groups Links
