I added a column to the resource scheduling board to show if the job is released. If I open the job and change the flag from true to false or vis versa and the refresh the scheduling board, My column does not refresh. Do I to refresh the grid in my customization?
Did you save the job before jumping back to the dashboard?
If you close and re-open the dashboard does it show correctly?
yes, i save the job and yes, it works if i exit the scheduling board and come back in.
I had to re-run my baq on refresh. Is there a way to have the column show a check instead of true or false
