Column Properties
Version 8.03.407A
Getting following error when paste code in
Compiling Custom Code ...
----------errors------------
Error: BC30188 - line 25 (150) - Declaration expected.
Error: BC30451 - line 36 (161) - Name 'Intialization' is not declared.
Error: BC30182 - line 42 (167) - Type expected.
Error: BC30108 - line 43 (168) - 'EpiDataView' is a type and cannot be used as an expression.
Error: BC30205 - line 43 (168) - End of statement expected.
Error: BC30800 - line 43 (168) - Method arguments must be enclosed in parentheses.
Error: BC30182 - line 45 (170) - Type expected.
Error: BC30108 - line 46 (171) - 'DataColumn' is a type and cannot be used as an expression.
Error: BC30205 - line 46 (171) - End of statement expected.
Error: BC30451 - line 54 (179) - Name 'Disposal' is not declared.
Error: BC30188 - line 62 (187) - Declaration expected.
Error: BC30182 - line 63 (188) - Type expected.
Error: BC30108 - line 64 (189) - 'EpiNotifyArgs' is a type and cannot be used as an expression.
Error: BC30800 - line 64 (189) - Method arguments must be enclosed in parentheses.
Error: BC30205 - line 64 (189) - End of statement expected.
Error: BC30451 - line 71 (196) - Name 'lookup' is not declared.
Error: BC30800 - line 71 (196) - Method arguments must be enclosed in parentheses.
Error: BC30451 - line 71 (196) - Name 'flag' is not declared.
Error: BC32017 - line 71 (196) - Comma, ')', or a valid expression continuation expected.
Error: BC30182 - line 81 (206) - Type expected.
Error: BC30108 - line 82 (207) - 'DataColumn' is a type and cannot be used as an expression.
Error: BC30205 - line 82 (207) - End of statement expected.
Error: BC30057 - line 87 (212) - Too many arguments to 'Private Function getDueDate(po As Integer, line As Integer) As Object'.
Error: BC30188 - line 92 (217) - Declaration expected.
Error: BC42021 - line 93 (218) - Function without an 'As' clause; return type of Object assumed.
Error: BC30203 - line 93 (218) - Identifier expected.
Error: BC30451 - line 94 (219) - Name 'rel' is not declared.
Error: BC30201 - line 94 (219) - Expression expected.
Error: BC30800 - line 94 (219) - Method arguments must be enclosed in parentheses.
Error: BC30201 - line 98 (223) - Expression expected.
Error: BC30454 - line 99 (224) - Expression is not a method.
Error: BC30201 - line 99 (224) - Expression expected.
Error: BC30800 - line 99 (224) - Method arguments must be enclosed in parentheses.
Error: BC30451 - line 99 (224) - Name 'rel' is not declared.
Error: BC30201 - line 100 (225) - Expression expected.
Error: BC30035 - line 101 (226) - Syntax error.
Error: BC30201 - line 103 (228) - Expression expected.
Error: BC30451 - line 104 (229) - Name 'dsRelease' is not declared.
Error: BC30203 - line 110 (235) - Identifier expected.
Error: BC30035 - line 111 (236) - Syntax error.
Error: BC32022 - line 112 (237) - 'Public Event AfterAdapterMethod(sender As Object, args As Epicor.Mfg.UI.FrameWork.AfterAdapterMethodArgs)' is an event, and cannot be called directly. Use a 'RaiseEvent' statement to raise an event.
Error: BC30451 - line 115 (240) - Name 'args' is not declared.
** Compile Failed. **
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> It is for Version 8....
> And you could try to paste it in - just watch for the text wrapping
> --- In vantage@yahoogroups.com, "kirsty2179" <dobby01@> wrote:
> > Thanks so this code can be copied into Script Editor?
> > --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > > See message 100682
> > > > Hi
> > > > Any help would be great we would like to add due date to Pending Receipt Lines
> > > > But in the column properties their is no Due date to Hide or unhide how can i add this field?
> > > > Thanks In advance
> > > > Kirsty
Hi
Thanks In advance
Kirsty
See message 100682
--- In vantage@yahoogroups.com, "kirsty2179" <dobby01@...> wrote:
> Hi
> Thanks In advance
> Kirsty
> See message 100682
> > Hi
> > Thanks In advance
> > Kirsty
> > See message 100682
> > > Hi
> > > Thanks In advance
> > > Kirsty
