You could try replacing View text with “EQMT2015” (without quotes), and set the Layer field to blank. Sometimes using the menuID works, at least from what I recall reading.
I have tried that. Same problem
You just lost me. what is the 9-dots?
The kinetic main menu. When you open that menu item from the main menu, do you get the custom layer?
No I do not. I get a blank screen. Let me work that angle and see if that is the problem.
Just wanted to let you know I got it to work! Thanks for you help.
Do tell.
Somewhere I messed up the copy of the I used to create my custom layer. I deleted my layer made a new one from the base and redid my customizations. So Josh’s method worked. Now I just need to finish the customizations.
