Combing 2 jobs, one is a split from the original made by mistake (with labor costs)
One of my planners had split a job that we did not need to split. The job now has labor costs associated with it and I need to combine the 2 together to dumb the labor costs on the original.
Please tell me there is another way other than adding the labor details to the original and cancelling the split. That would be a MAN-VAR issue at that point.
1: on the job you are keeping: in job entry, increases the job production size.
2: using job adjustments, do negative adjustments out of the bad job, and positive adjustments into the good job. This should result in the bad job haveing zero cost.
3: go to job closing and close out the bad job.
Thank you for your help!
