I have a custom layer we have been using on order entry - CustomerServiceBase. One field is a custom text box that uses a transview to a baq to calculate the total weight of the order (to see if it will exceed 40k truckload max). This field has worked until we updated our order entry screen with custom layer required to run or credit card software (Ebiz). I was told to combine the layers on the menu and give priority to the Ebiz layer. All other fields from our custom layer still work and so do the Ebiz ones, except for this transview text box.
Just our customer service base layer -
Combining layers at menu level same order-
Any ideas on why this field would fail? Should I be combining these layers differently?
