Half baked idea from far left field....could get really messy if lots of groups and/or reps but:
Create a different rep code for each rep for each group. Like Reps 1 thru 5 and groups A thru E:
1A
1B
1C....
2A
2B....
and assign rates to each. Still would still mean manually getting the right rep code on each line but if the actual rep/group codes were somewhat descriptive of the groups it would be easier to spot than a rate difference. Commissions reporting would be a little messier to consolidate for a given rep but nice in that they would have product group level totals. If you coded the group part the same as the actual product group code you could have an easy audit report to spot inconsistancies at the end of the day well before invoicing.
-Todd C.
Sent: Wednesday, May 25, 2005 12:06 PM
Subject: [Vantage] Commissions based on Product Group
Is there anyway to setup the system to decide a line's commission by
product group? This is our commission structure here and it means
manually changing the commission on every line item.
Anyway to automate?
Ben
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
1A
1B
1C....
2A
2B....
-Todd C.
Anyway to automate?
Ben
_____
Yahoo! Groups Links
