Any chance you could elaborate w/ more details and specifics?
Appreciate it.
Sent: Tuesday, July 5, 2011 5:34 PM
Subject: Re: [Vantage] Company config email to external SMTP server workaround
Â
Appreciate it.
Â
>[Non-text portions of this message have been removed]
>Create an inhouse relay server.
>Any computer running windows Server 2k, 03, or 08 has this capability.
>1- Set it up to accept mail without authentication from 1 server, and one
>server only, your Epicor Server, by IP address not server name.
>2- On your relay server, you are able to put in your username and password
>for your external email provider so it can forward the mail to the end
>location.
>This will forward all mail received from the epicor server to your relay
>server to your external provider with all appropriate permissions etc.
>If you are really concerned about SPAM or malware causing a problem, then
>you can always set up some strange, obscure port number for receiving SMTP
>emails on your relay server so that you don't need to worry about that
>malware or bot using 25 or 587 in it's default settings to take advantage of
>your open port, and the fact that only your epicor server would be allowed
>to connect in the first place means you would only need to worry about
>malware on that machine, which in general I think is a computer with a very
>low risk of getting malware of any kind in the first place.
>On Tue, Jul 5, 2011 at 3:19 PM, jim_chance <jim_chance@...> wrote:
>> Does anyone have a solution - workaround for a situation where the company
>> config SMTP servert is to an external provider and there is no user and
>> password setup capability in the email tab/window for 8.03?
>> We don't have a redirect, relay, trusted relathionship, authentication -
>> inhouse email server scenario.
>> How are companies working around this challenge?
>> Special config/redirect w/ user/pass setup? If yes, how was this done, what
>> does it look like?
>> This is indeed problematic.. Especially when companies are using user/pass
>> to avoid spam/bouncing and don't have an email server.
>> Ideas?
>> Thank you.
>> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
>> already linked your email address to a yahoo id to enable access. )
>> (1) To access the Files Section of our Yahoo!Group for Report Builder and
>> Crystal Reports and other 'goodies', please goto:
>> http://groups.yahoo.com/group/vantage/files/.
>> (2) To search through old msg's goto:
>> http://groups.yahoo.com/group/vantage/messages
>> (3) To view links to Vendors that provide Vantage services goto:
>> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
