Company email setup 8.0
Mark,
I believe there are two different settings which control two
different functions that need to be set:
1. Auto Email (Global Alerts) uses the settings under the Company ->
Email Tab.
2. On the Vantage menu under File -> Send -> Record by Email or when
you get a dialog box containing an error that you can email, use the
settings in the .mfgsys file. Locate of add the entry <SmtpServer
value="MYMAILSERVER"> in the <usersettings> section. This is the one
that I believe is causing you problems. I thought you could also set
the port, but I didn't see it in our file. My guess is that it is
using the default SMTP port 25.
As far as the Email Link Port... I'm not exactly sure what that is
for, but if you set the above, your problem should be resolved.
Hope this helps.
Cheers!
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@y...>
wrote:
> I'm sure this is easy - and it sounds like I don't want to call
support...
> In the Company setup (8.0), under the email tab, there's "Email
Link Port".
> Exactly which port number do they want? The appserver port number,
the
> database port number? The taskAgent port number?
> We get the error:
> "Failed to connect to SMTP server; email attempt aborted. Please
confirm the
> SMTP setting in your XXX.Mfgsys AppSettings file.
> I have gone to our Vantage server and am able to connect to the SMTP
> (Exchange) server, so it is not a relaying issue.
> Thanks,
> Mark W.
I'm sure this is easy - and it sounds like I don't want to call support...
In the Company setup (8.0), under the email tab, there's "Email Link Port".
Exactly which port number do they want? The appserver port number, the
We get the error:
"Failed to connect to SMTP server; email attempt aborted. Please confirm the
Mark W.
I'm on 6.1 so this may not be the same for 8.0, but we were told it
just needs to be any unused port #. We are using 5001.
HTH,
Brian Stenglein
Clow Stamping Co.
support...
Link Port".
the
> We get the error:
confirm the
> Thanks,
> Mark W.
In 8.0 you are to use any port over 7000, we use 7777
Of Mark Wonsil
Sent: Thursday, January 26, 2006 1:00 PM
Subject: [Vantage] Company email setup 8.0
support...
Port".
We get the error:
the
Mark W.
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
I opened a command window on the Vantage server (Start | Run | cmd) and did a:
C:\>netstat
This showed all used port numbers. I saw that the range that Gerard suggests
and 5001 were both available. I tried both and still no luck.
So I browsed to C:\Client80\client\config and looked in the local settings
file: XXX.mfgsys, where XXX = train, pilot, test, default, ...
Under the <usersettings> element, I found that the last element did not
contain the smtp server name.
<SmtpServer value=" " />
I added that in and it worked like a charm.
I appreciate the response and I hope this helps others.
Mark W.
