BINGO.Â
That
That
--- On Tue, 11/25/08, bw2868bond <bwalker@...> wrote:
Subject: [Vantage] Re: Compile Error: Type 'CompanyAdapter' is not defined.
Date: Tuesday, November 25, 2008, 11:27 AM
You most likely need to add the Company adapter dll files in the
customization - tools - assembly reference manager
Add both the AD and IF dll files for Company
--- In vantage@yahoogroups .com, Ahmet Erispaha <ahmeterispaha@ ...>
wrote:
> I'm trying to auto-generate part numbers for new parts and getting
a "Type 'Company Adapter' is not defined" error. I adapted this code
from a customization workshop which was originally written to create
customer numbers -- that customization, by the way works fine. (The
customization uses Number01 in the Company table to store the latest
number used.)
> Â
> I have the same "Imports" statements in both versions. I need help
understanding why the new customer customization recognizes
CompanyAdapter but the new part customization doesn't. Is there some
inherent connection between Company and Customer that is missing
between Company and Part?Â
> Â
> Here is the EpiViewNotification code for both:
> Â
> ***New customer***this one compiles
> Â Â Â Private Sub edvCustomer_ EpiViewNotificat ion(view As
EpiDataView, args As EpiNotifyArgs) Handles
edvCustomer. EpiViewNotificat ionÂ
> Â Â Â Â Â Â Â If (args.NotifyType = EpiTransaction. NotifyType. AddRow)
Then
> Â Â Â Â Â Â Â Â Â Â Â If (args.Row > -1) Then
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Dim compAdapt As CompanyAdapter = New CompanyAdapter
(CustomerEntryForm)
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compAdapt.BOConnect ()
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Dim company As String =
CustomerEntryForm. Session.CompanyI D
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Dim ret As Boolean = compAdapt.GetByID( company)
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Dim newCustID As Integer =
compAdapt.CompanyDa ta.Tables( "Company" ).Rows(0) ("Number01" )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â view.dataView( args.Row) ("CustID" ) = "Auto" +
newCustID.ToString( )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â view.Notify( New EpiNotifyArgs( CustomerEntryFor m,
view.Row, view.Column) )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â newCustID = newCustID + 1
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compAdapt.CompanyDa ta.Tables( "Company" ).Rows
(0).BeginEdit( )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compAdapt.CompanyDa ta.Tables( "Company" ).Rows(0)
("Number01") = newCustID
(0).EndEdit( )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compAdapt.Update( )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compAdapt.Dispose( )
> Â Â Â Â Â Â Â Â Â Â Â End If
> Â Â Â End Sub
> ***New part***this one doesn't
> Â Private Sub edvPart_EpiViewNoti fication( view As EpiDataView, args
As EpiNotifyArgs) Handles edvPart.EpiViewNoti fication
> Â Â If (args.NotifyType = EpiTransaction. NotifyType. AddRow) Then
(PartForm)
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Dim company As String = PartForm.Session. CompanyID
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Dim newPartID As Integer =
compAdapt.CompanyDa ta.Tables( "Company" ).Rows(0) ("Number02" )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â view.dataView( args.Row) ("PartNum" ) = "Auto" +
newPartID.ToString( )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â view.Notify( New EpiNotifyArgs( PartForm, view.Row,
view.Column) )
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â newPartID = newPartID + 1
(0).BeginEdit( )
("Number02") = newPartID
(0).EndEdit( )
> Â Â
> Â Â Â End If
> Â Â End If
> Â End Sub
> Thanks,
> Â
> Ahmet Erispaha
> Â
