Compiled Crystal Report Problem
And don't forget to erase all files in the Vantage (and Windows) Temp
directories. File residue causes problems with Crystal Reports. What you're
describing is exactly what happened to us -- and clearing the directory was
the solution -- get out of Vantage first.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, June 27, 2005 6:43 AM
Subject: RE: [Vantage] Compiled Crystal Report Problem
> Anothe thing to try in the clients is to run the Crystal Decisions
Database and Export Patch, found on the Epicor FTP site, on each client that
needs to run the report. This is a pretty common fix for when reports drop
detail line info after the first one.
> -Todd C.
> -----Original Message-----
> From: Michelle de la Vega [mailto:mdelavega@...]
> Sent: Monday, June 27, 2005 7:50 AM
> To: vantage@yahoogroups.com
> when you compile a report it generates a file called setup.exe which is
> located in the UD folder. Install this on the clients, this should fix
> the problem.
> If that doesn't work then it might be a .dll problem
> _____
> Of furnitureman65
> Sent: Monday, June 27, 2005 8:16 AM
> Subject: [Vantage] Compiled Crystal Report Problem
> I have successfully compiled a Crystal report that was modified from the
> job traveller
> report. The compiled reports work fine, but now, on the clients I have
> installed the
> complied report, the original job traveller does not work properly. The
> first assembly
> prints properly, but all the remaining assemblies print header
> information only, without
> materials aamd opertaions. I am assuming I did something wrong when I
> installed the
> compiled report.
> (1) What did I do wrong?
> (2) How do I fix the clients that are not working?
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> _____
> YAHOO! GROUPS LINKS
> * Visit your group "vantage
> < http://groups.yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service < http://docs.yahoo.com/info/terms/> .
> _____
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> <?---- LSpots keywords ?><?---- HM ADS ?>
> _____
> YAHOO! GROUPS LINKS
> * Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on
the web.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> _____
> Yahoo! Groups Links
I have successfully compiled a Crystal report that was modified from the job traveller
report. The compiled reports work fine, but now, on the clients I have installed the
complied report, the original job traveller does not work properly. The first assembly
prints properly, but all the remaining assemblies print header information only, without
materials aamd opertaions. I am assuming I did something wrong when I installed the
compiled report.
the problem.
_____
Of furnitureman65
job traveller
installed the
first assembly
installed the
compiled report.
_____
YAHOO! GROUPS LINKS
<http://groups.yahoo.com/group/vantage> " on the web.
Service <http://docs.yahoo.com/info/terms/> .
_____
Anothe thing to try in the clients is to run the Crystal Decisions Database and Export Patch, found on the Epicor FTP site, on each client that needs to run the report. This is a pretty common fix for when reports drop detail line info after the first one.
-Todd C.
the problem.
_____
Of furnitureman65
job traveller
installed the
first assembly
installed the
compiled report.
_____
YAHOO! GROUPS LINKS
_____
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
