System.Environment.MachineName
I'm trying to retrieve the computer name from inside a method directive but it seems to want to return the server name instead. Is there anyone that knows how to call the client's name or easily pass the name to the directive?
Thanks.
On Mon, Jan 25, 2016 at 12:06 PM, don.n.doan@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span>System.Environment.MachineName<br></span></p><p><span><br></span></p><p><span>I'm trying to retrieve the computer name from inside a method directive but it seems to want to return the server name instead. Is there anyone that knows how to call the client's name or easily pass the name to the directive?</span></p><p><span><br></span></p><p><span>Thanks.</span></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
I am doing the same thing as we speak, however I am doing it all customization side. So when I launch the method that does the printing. I have a form popping that is preloaded with a printer based on the computer name (client side). I also have the list of the rest of similar label printer just in case the one that it SHOULD print to has crapped out for some reason (a plan B)
Joshua Giese
Technology Solutions : CTO
Direct Phone:
920.593.8299
Office Phone:
920.437.6400 x342
Sent: Monday, January 25, 2016 11:38 AM
Subject: [Vantage] Re: Computer Name from inside a Method Directive
I'm trying to select a label printer based on where the user is printing from.
That was my first thought, I just thought someone might have an easier way.
Thanks.
Jose C Gomez
T: 904.469.1524 mobile
On Mon, Jan 25, 2016 at 12:38 PM, don.n.doan@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>I'm trying to select a label printer based on where the user is printing from. </p><div><br></div><div>That was my first thought, I just thought someone might have an easier way.</div><div><br></div><div>Thanks.</div><p></p> </div><span class="ygrps-yiv-692719305"> <div style="color:#fff;min-height:0;"></div>
Jose C Gomez
On Mon, Jan 25, 2016 at 1:07 PM, don.n.doan@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Unfortunately I have a general warehouse user that all our floor guys use.</p> </div><span class="ygrps-yiv-1388897541"> <div style="color:#fff;min-height:0;"></div>
I they are using one user, but different employee ID’s you could do Jose’s same idea but on EmpBasic instead of User
Joshua Giese
Direct Phone:
920.593.8299
Office Phone:
920.437.6400 x342
Sent: Monday, January 25, 2016 12:10 PM
To: Vantage <vantage@yahoogroups.com>
Subject: Re: [Vantage] Re: Computer Name from inside a Method Directive
Then your best bet is to use a BPMDataForm and askthem which Printer They want... actually... this might work and its SUPER HACKY but if it works it would be sleek...
BPMData forms are available in the Client Space.... so you could have a BPM DataForm that Prompts with Nothing.... but in a customization it looks up the workstation ID and sets Character01 of BPMDatafield to that, then it self closes... The users may see a brief window flash up/down but that would automatically capture the machine name and then you can process everything from BPMCharacter01.
Jose C Gomez
Software Engineer
T:
904.469.1524 mobile
Jose C Gomez
On Mon, Jan 25, 2016 at 4:51 PM, don.n.doan@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>So I'm testing out the BPM Form idea. Seems like it would work pretty well except for the fact that I need a PerformClick() on the OK button. This doesn't work on load since the form isn't in view. On shown doesn't want to work(Not sure if it even exists).  </p><div><br></div><div>On load BPM.Character01 is loaded with the PC name but I cant get it to accept it.</div><div><br></div><div>I can't figure out where to trigger the click. Any ideas?</div><p></p> </div> <div style="color:#fff;min-height:0;"></div>
