Using the row-update widget I need to concatenate two strings together. If one of them has a single quote in it, the concatenation will add \\ into my string.
Is there a way to prevent this?
Ok so turns out using JSON fixes it. Its the Expression field that doesnt work correctly for that matter.
If you feel like playing, I think you can remove the double \ at the end of your expression:
('{TransView.FirstString}' + '{TransView.SecondString}').replace(/\\/g, "")
