Conditionally Hiden and unable field in form
Hi, have tried that one and still nothing seems to update. in the code below I just put in a simple checkbox03 change to see if it will update. Eventually it will be a combo box hide combobox show.
Private Sub edvDMRActnReject_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvDMRActnReject.EpiViewNotification
'// ** Argument Properties and Uses **
'// view.dataView(args.Row)("[FieldName]")
'// args.Row, args.Column, args.Sender, args.NotifyType
'// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
If (args.NotifyType = EpiTransaction.NotifyType.AddRow) Then
If (args.Row > -1) Then
if view.dataview(args.row)("Checkbox03")= true then
view.dataView(args.Row)("Checkbox03") = false
end if
End If
End If
End Sub
--- In vantage@yahoogroups.com, "Sean McDaniel" <smcdaniel@...> wrote:
> Can't you hook into the EpiViewNotification Init event?
> From: vantage@yahoogroups.com on behalf of Rupert
> Sent: Wed 12/8/2010 10:05 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Conditionally Hiden and unable field in form
> I'm trying to conditionally hide and un-enable a Combi box on a form whilst enabling another on the same form.
> The condition is based on the part number, and is on the DMR Processing screen. At present I can't seen to trigger any actions within the DMR Processing to allow me to do this.
> The Problem I'm having is that the Part field is not changed within this form.
> has anyone done similar they're willing to share?
