If they are set as 'Materials', ie, the Pull as Assembly checkboxes are
un-checked, then they will generate orders to make the parts. If they
are coming into the order as subassemblies, then they should have the
standard MOM for the actual part number being put in there. That is the
exact way we do things.
Are you 'getting details' on the job when they come across without the
MOM on them? We had that type of issue if we went back into the
Configurator setup and modified some of the code in there, it would then
run MRP but not give us the MOM and subassemblies it was supposed to.
You can try a delete all at the top level, then get details manually to
see if you get an error back from that process or not. If it does work
manually then I would get with Epicor about the issue. I am in
discussions with them right now because of a similar situation, but in
our case we do a quote which already has the details on it for some
custom issues, but the MRP is not pulling in the details from the quote
like it should.
Paul Millsaps
Time Manufacturing
254.399.2170
paulm@... <mailto:paulm@...>
This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mistransmission.
If you receive this message in error, please immediately delete it and
all copies of it from your system, destroy any hard copies of it and
notify the sender. You must not, directly or indirectly, use, disclose,
distribute, print, or copy any part of this message if you are not the
intended recipient.
Of gmack110256
Sent: Tuesday, October 14, 2008 8:29 AM
Subject: [Vantage] configurator
i will give an example of what we are doing. we have a placeholder for
part "svertical", it pulls in 1 of 6 different parts. the parts being
pulled in have operations and materials atttached to them. when the
configurator is ran it fills in the placholder with the proper part
but does not pull in the operations or material requirements with the
chossen part.
the placeholders themselves do not have any operations attached to
them.
when a job is produced against the order for the configured part it
only list the parts required for the configuration. Does each of
these parts pulled in have to have it's own job created to
manufactured it? I am very new at trying to make this work an any
pointers would be greatly apperciated.
Gene
like it should.
Paul Millsaps
Time Manufacturing
254.399.2170
intended recipient.
Of gmack110256
chossen part.
them.
Gene
