Thank you, Mark. I will explore that direction.
Ross
Ross
--- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@...> wrote:
> Hi Ross,
> > Is there a way to display a dynamic price total on a configurator screen while the options are being selected?
> > When I test the inputs it is displaying the resulting price in a messagebox. I was thinking this is available in a configurator variable that I can just present in a text box, etc.
> > Or, is this something I need to code from the PCx tables?
> I believe that once the current configuration has all of the PC
> Values, it calls the Configuration business object method called
> ApplyOrderPricing, or ApplyQuotePricing or something similar in V8.
> I'm not sure what the behavior is if all of the input values are not
> given. If you can get handles to the datasets required then you could
> call this method on the configuration object and it will return a
> total and base price. That is, of course, you're using the pricing
> mechanism in the configurator. If you can calculate the price on your
> own, assign it to an input, and then assign it to the price in the
> end, then you have total control and just call your pricing routine on
> every On Leave and update the current price.
> Mark W.
