We create BOM's from Quote that work fine, not sure what support is talking about but I'd like to know their reasoning, my guess would be a problem in 'set-fields' being correct for 'jobs' but maybe not correct for 'quotes'..
Mark Wonsil <mark_wonsil@...> wrote: Hi Charles,
have not seen differences between Get Details in Quotes or in Job Entry
though.
you can only do that in Quote Entry or Job Entry. There is no Get Details in
Order Entry (unless it's new...)
You can get different MOMs between Job Entry and Quote Entry if you are using
Set Field rules, changing quantities for example. You must create a rule for
quote field and then another rule for job fields. Keep When rules work the
same for both tables however.
Can you narrow it down to the part that it starts messing up on and paste the
rule(s) in a message for us?
Mark W.
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
> If we use the configurator from either Order Entry or Quote Entry itWhen this happens to me, it's almost always an error in one of my rules. I
> does not create a correct BOM, however, from Job Entry Get Details it
> will. Everything is fine to a point but as it gets further down into
> the configuration it seems to ignore the Keep When statements and
> selects everything.
though.
> I was wondering if anyone else has run across a similar problem andJust to be clear, the MOM is only created during a Get Details operation and
> if there is a solution to it. We have been told by support that for
> the configurator to create a correct BOM it must be done from job
> entry. This seems ludicrous to me. This creates a lot of extra work
> for us and forces us to give order entry personnel authority to job
> entry and engineering workbench just to get the system to create a
> correct BOM for MRP.
Mark W.
