Configuring Change Logs
Does anyone have easy to follow instructions on how to create/configure change logs for a certain module?
Thanks!
If you are on E-10 in the help files there is a step by step instruction on how to set up a change log. It’s pretty simple so you should be able to extrapolate the example to most places in the system. After you look up the example in the help files, let us know if you still have questions. I would post a screen shot of the help article but it seems like my help system is on the fritz today (for some reason we have trouble with the help not working all of time)
thanks!
Its under “Enable Change Log Directive”
