Connecting to a 2nd progress database?
Kevin -
Did you add the entry on the Terminal Server for the services/port
number for the other db?
Sent: Monday, July 21, 2003 9:14 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Connecting to a 2nd progress database?
I am having trouble connecting to another progress database from within
Vantage while using a metaframe client.
I have setup an additional database and made an entry into the Progress
Auto-Connect List via the Data Admin tool. I access this database when
inside Vantage via a VBForm and some 4GL code (Connect Statements). This
works perfectly for ALL vantage clients except those connecting via Terminal
Server 4.0/ Metaframe. When a user using Metaframe logs onto Vantage and
opens the VBForm (Should connect automatically to other dbase) they get an
error after about a minute of "freeze time". The error is:
* Could not connect to server for database \\VantServer\Tooling\DB\tooling,
error 0 (1432).
This works fine from all other clients as long as it's not via terminal
server. Even if I am logged into the Terminal Server as Admin the same
thing happens. I can get to the above database directory from the run
command in Terminal server just fine and vantage works perfectly in every
other aspect.
Any ideas?
Kevin Larkin
401-941-8876
Ferguson Perforating
error 0 (1432).
other aspect.
Any ideas?
Kevin Larkin
401-941-8876
