Connection string for ODBC
I still get an error...
"Driver={SQLServer}Server=Epicor
Production;Database=Epicor904;UID=sysprogress;PWD=sysprogress;"
Ned
Sent: Wednesday, May 19, 2010 1:25 PM
Subject: RE: [Vantage] Connection string for ODBC
No
If you are using a SQL DB then you don't have anything to do with OpenEdge
at
all, you should be connecting directly to the SQL server.
If you are using an MS SQL DB then you will use one of these 2 for an ODBC
connection string.
Standard Security:
"Driver={SQLServer};Server=Your_Server_Name;Database=Your_Database_Name;Uid=
Your
_Username;Pwd=Your_Password;"
Trusted connection:
"Driver={SQLServer};Server=Your_Server_Name;Database=Your_Database_Name;Trus
ted_
Connection=yes;"
Behalf Of
advantage@... <mailto:advantage%40wcoil.com>
Sent: Wednesday, May 19, 2010 12:07 PM
Subject: Re: [Vantage] Connection string for ODBC
ok, so I am assuming for Epicor9 it would be as follows. SQL database.
Also, did not setup an odbcuser/odbcuser password through openedge.
Shouled we?Do I have to or can it remain sysprogress\sysprogress
Mode=Read?
"DSN=Epicor
Production;HOST=ServerName;PORT=9001;DB=Epicor904;UID=sysprogress;PWD=syspro
gres
s;Mode=Read"
> here's one we use (ver 6.10.541 ) :
> Â
> 'DSN' is set up as a 'sytem' DSN.
> Â
> adoConnect.ConnectionString =
"DSN=eeVantage_Mfg;HOST=eevantage;PORT=6150;DB=mfgsys;UID=odbcuser;PWD=odbcu
ser;
Mode=Read"
> --- On Wed, 5/19/10, advantage@... <mailto:advantage%40wcoil.com>
<advantage@... <mailto:advantage%40wcoil.com> > wrote:
> From: advantage@... <mailto:advantage%40wcoil.com>
> Subject: [Vantage] Connection string for ODBC
> Date: Wednesday, May 19, 2010, 10:57 AM
> Â
> Can anyone quickly give me connection string to setup access thru ODBC to
> an Epicor 9 db
> Sent from my Verizon Wireless BlackBerry
Can anyone quickly give me connection string to setup access thru ODBC to an Epicor 9 db
Â
Â
adoConnect.ConnectionString = "DSN=eeVantage_Mfg;HOST=eevantage;PORT=6150;DB=mfgsys;UID=odbcuser;PWD=odbcuser;Mode=Read"
Â
Mode=Read?
"DSN=Epicor
Production;HOST=ServerName;PORT=9001;DB=Epicor904;UID=sysprogress;PWD=sysprogress;Mode=Read"
> ÂÂ
> ÂÂ
> From: advantage@... <advantage@...>
> ÂÂ
> an Epicor 9 db
No
If you are using a SQL DB then you don't have anything to do with OpenEdge at
connection string.
Standard Security:
"Driver={SQLServer};Server=Your_Server_Name;Database=Your_Database_Name;Uid=Your
Trusted connection:
"Driver={SQLServer};Server=Your_Server_Name;Database=Your_Database_Name;Trusted_
Connection=yes;"
advantage@...
Mode=Read?
"DSN=Epicor
s;Mode=Read"
> ÂÂ
> ÂÂ
Mode=Read"
> ÂÂ
> an Epicor 9 db
If you are connecting to an OpenEdge database, you should really be setting it to Mode=READ UNCOMMITED to prevent any possibility of a record lock during the access to the DB.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Bill Jackson
Sent: Wednesday, May 19, 2010 11:48 AM
 THat's what our 'DSN' is set to.
Date: Wednesday, May 19, 2010, 4:21 PM
Â
