If you keep the DSN set as "Read UnCommitted" you should be safe with this method. Some of the ODBC dlls (10+ years ago) didn't follow the dsn setting for record locking, if you find that record locking is still occurring on your system can also add "nolock" to the SQL commands.
Between the business objects and the web services, we've found the web services function at a 1/3 of the speed of the business objects. I think this is why Service Connect changed between earlier versions of 8.03.
HTH,
Calvin Dekker
Office: 630-672-7688 Ext. 1484
Email: calvin@...<mailto:calvin@...>
http://www.codabears.com<http://www.codabears.com/>
[cid:image001.jpg@...3E960]<http://www.codabears.com/>
Solutions for Epiday living.
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
Sent: Thursday, July 25, 2013 7:31 AM
Subject: RE: [Vantage] Connection string to the Epicor database from .Net page?
I urge you not to do the below mentioned. It is a very scary practice and
is a huge no no if you have Epicor support. You are setting yourself up
for record locks and all sorts of troubles. Just would make me nervous
running SQL direct like that. If you do something like this at the least
use views if your on SQL for the love of all that is holy!
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Calvin Dekker
Sent: Thursday, July 25, 2013 6:55 AM
page?
Todd -
Are you using Progress or SQL? A google search on "connection string
<database-type>" will pull up examples. For Progress, we use:
"DSN=E9ODBC;uid=sysprogress;pwd=sysprogress"
E9ODBC is the name from the ODBCad32 data source.
Here's a code example that returns a data table with the results for a SQL
query:
'Add a reference to:
Imports System.Data.ODBC
'Define variables:
Dim DSN As String = "Dsn=E9ODBC;uid=sysprogress;pwd=sysprogress"
Dim sQuery As String = "SELECT CustID, Name, Address1, City, State, Zip
FROM PUB.Customer WHERE Company = '1234' AND State = 'IA' ORDER BY Name"
Dim dsCustomers as DataTable = EpicorData(sQuery, DSN)
Public Function EpicorData(sQuery, sDSN) As DataTable
'Declare the dataset and set the connection string
Dim eDS As DataSet = New DataSet
'Declare the ODBC connection and open the connection
Dim Epicor9 As Odbc.OdbcConnection = New Odbc.OdbcConnection(DSN)
Epicor9.Open()
'Declare data adapter with SQL query and ODBC connection passed to it
Dim eAdapter As New Odbc.OdbcDataAdapter(sQuery, Epicor9)
'Fill data adapter with Data Source and Table Name
eAdapter.Fill(eDS, "Pub.Customer")
Epicor9.Close()
'Return Tables from function
Return eDS.Tables(0)
End Function
HTH,
Calvin Dekker
Email: calvin@...<mailto:calvin%40codabears.com> <mailto:calvin%40codabears.com>
<mailto:calvin@...<mailto:calvin%40codabears.com> <mailto:calvin%40codabears.com> >
[cid:image001.jpg@01CE8903.D850BC40<mailto:image001.jpg%4001CE8903.D850BC40>
<mailto:image001.jpg%4001CE8903.D850BC40> ]<http://www.codabears.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of todd@...<mailto:todd%40massprecision.com> <mailto:todd%40massprecision.com>
Sent: Wednesday, July 24, 2013 9:47 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Connection string to the Epicor database from .Net
page?
Looking for the exact syntax for specifying the connection string in order
to connect to the Epicor database from .Net page. Can anyone help?
Todd Gilbert
MASS Precision, Inc.
HTH,
Calvin Dekker
Joshua Giese
CTO
Of Calvin Dekker
page?
Todd -
query:
'Define variables:
Epicor9.Open()
Epicor9.Close()
End Function
HTH,
Calvin Dekker
page?
Todd Gilbert
