Constrained Material
Amy,
(See Dale's post below)... Apparently it IS an AMM license issue. The consenus seems to be that without AMM, all jobs treat stocked materials as constrained. Dale feels it is when forward scheduling. Knowing intimately how lame the scheduler is (with AMM), I'm not convinced it really matters (as much of what is claimed behavior logic has proven not to be true).
You could probably test the theory by making up a fictitious purchased stocked part with (say) a 1000 day lead time, adding it to a job as a material detail (linked to the 1st OP), and then seeing if the scheduler delays the job 1000 days (scheduling the job forward and then backward).
Very curious as to what that might reveal...
Rob
cpsadp <cpsadp@...> wrote:
HI Rob,
I don't think you failed me, and I truly do appreciate the effort.
In my case, the parts are stocked. (We don't have any non-stock
parts). I'm just baffled as to why I cannot mark ANY of them
constrained.
amy
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
> Sorry Amy, I think I struck out on providing any help.
> According to Dale (see his post) it is not an AMM dependent
feature.
> I just tried, and I'll be darned if I can set up a Part in any
way that it results in it NOT being able to be set as Constrained.
(I'm checking this on 8.03.404).
> Perhaps on past versions, if a part is already set to
make/purchase direct, the checkbox field becomes non-editable (since
make/purchase direct parts ARE 'constrained' by definition).
> Any chance your parts are make/purchase direct already?
> If not, sorry I failed you.
> Rob Brown
> No, I'm not. Is that the answer? It didn't specify in the
help
> files that constrained material belongs to a different module.
> amy
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
> wrote:
> > Are you licensed for advanced scheduling/materials management?
> > cpsadp <cpsadp@> wrote: Hi,
> > I want to do some testing with constrained materials (V.
8.00.811B)
> but
> > the check box for constrained mateial is greyed out on all parts.
> > Anyone know the secret to being able to mark a material as
> constrained?
> > amy
> > Be a better friend, newshound, and know-it-all with Yahoo!
Mobile.
> Try it now.
> Be a better friend, newshound, and know-it-all with Yahoo! Mobile.
Try it now.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Hi,
I want to do some testing with constrained materials (V. 8.00.811B) but
Anyone know the secret to being able to mark a material as constrained?
amy
cpsadp <cpsadp@...> wrote: Hi,
amy
Forward Scheduling will automatically use material due dates in the
scheduling calculations even without Adv. Scheduling.
This was broken in some versions on 8.03.3XX but has been fixed in the
latest 8.03.4XX.
Dale Schuerman
Sr. Consultant
RAM Software Systems, Inc.
972-669-0763
Of Robert Brown
Sent: Monday, March 03, 2008 9:56 AM
Subject: Re: [Vantage] Constrained Material
cpsadp <cpsadp@... <mailto:cpsadp%40yahoo.com> > wrote: Hi,
amy
it now.
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
No, I'm not. Is that the answer? It didn't specify in the help
amy
but
constrained?
> amy
Try it now.
Thanks for the heads up Dale. I had given up on it on 305 (as it produced pretty flaky, often inexplicable results). I'll give it another test on 404.
I guess I was also barking up the wrong tree (re: Amy's original post) as I incorrectly assumed it was an AMM license (which we have always had) dependent capability.
Re: Amy's problem: I seem to recall Constrained materials must be non-phantom, stocked, qty bearing parts (or the Part can not be set to constrained). I'm fuzzy on whether they also have to be set for MRP processing.
Rob Brown
latest 8.03.4XX.
Dale Schuerman
Sr. Consultant
972-669-0763
Of Robert Brown
amy
it now.
Attention:
by MailMarshal SMTP
Never miss a thing. Make Yahoo your homepage.
According to Dale (see his post) it is not an AMM dependent feature.
I just tried, and I'll be darned if I can set up a Part in any way that it results in it NOT being able to be set as Constrained. (I'm checking this on 8.03.404).
Perhaps on past versions, if a part is already set to make/purchase direct, the checkbox field becomes non-editable (since make/purchase direct parts ARE 'constrained' by definition).
Rob Brown
amy
but
constrained?
> amy
Try it now.
Rob,
I think we are both right. Setting the constrained flag on specific
parts is AMM dependent.
Without AMM, forward scheduling all parts are constrained. This can be
overridden on the scheduling options menu (then none of the parts are
constrained).
Hope this helps.
Dale Schuerman
Sr. Consultant
972-669-0763
Of Robert Brown
Sent: Tuesday, March 04, 2008 7:23 AM
Subject: Re: [Vantage] Re: Constrained Material
this on 8.03.404).
Rob Brown
amy
but
constrained?
> amy
Try it now.
it now.
Attention:
by MailMarshal SMTP
HI Rob,
constrained.
amy
feature.
> Rob Brown
help
> amy
8.00.811B)
> but
> constrained?
> > amy
Mobile.
> Try it now.
Try it now.
Amy
The APS (Advance Production Scheduling) module enables this field
allowing you to mark stocked items as constrained in the part master.
Gary
Dot Net IT Limited, Reg No 4412519
Of cpsadp
Sent: 04 March 2008 21:52
Subject: [Vantage] Re: Constrained Material
HI Rob,
constrained.
amy
feature.
> Rob Brown
help
> amy
8.00.811B)
> but
> constrained?
> > amy
Mobile.
> Try it now.
Try it now.
